gingerprince
posted on 28/5/12 at 07:24 PM |
Road Dyno test of new Air Box
So after building my airbox to quieten my induction : http://www.locostbuilders.co.uk/viewthread.php?tid=169982
I decided I wanted to see whether it had impacted performance in any way. So I went for a play a couple of days ago, and did a crude comparison of
the car accelerating with the airbox, versus without. Basically found a stretch of road, ran it both with and without the airbox, in 4th and 5th gear
on separate runs. I recorded rpm over time using my Digidash for each run and plotted in Excel: -
![](/galpreviews/3dyno.jpg) ![Description](/gallery/3dyno.jpg) Description
Basically, it seems that to all intents and purposes the airbox makes no perceivable difference to performance - which is exactly what I hoped for!
I've also been having a play with the Road Dyno spreadsheet available here :
http://www.iwsti.com/forums/how-install/135450-road-dyno-your-car-complete-noobs-guide-56k-run-away.html
Tweaking around with the numbers for gear ratio's, drag coefficients etc I've got something that looks a reasonable approximation to what
I got the last time I was on the rollers: -
![](/galpreviews/road dyno plot.gif) ![Road Dyno Plot](/gallery/road dyno plot.gif) Road Dyno Plot
I didn't hold much past 10000rpm so don't see the roll-off.
I don't expect the numbers to be accurate, and there's a lot of "rounding" goes on to smooth out the graph, but this again
seems to suggest the airbox isn't impeding performance.
The "with airbox" line does seem a bit more "wiggly" than the without. I'll need to do multiple runs to know whether
that's just how the data looked for that run or symptomatic. Probably reading too much into it, but it but I guess it could be resonance and
harmonics (though every 500rpm?), or running out of air, refilling and being happy again?
I'm tending to think it's just the data though - certainly didn't "feel" to be jumping around, and as my previous post
the rpm over time looks pretty much identical.
I've since run a cold air feed from the nose to the filter (not mounted the filter there because it doesn't fit!), so I'll probably
do a back-to-back with that at some point to see if there's a discernable difference.
So overall I'm fairly happy that it quietens things down without impacting performance - which was nice.
bi22le
posted on 28/5/12 at 10:15 PM |
Thats a nice build and good info on how to do it, cheers.
I can see me needing to do one of these. My sausage filter is through the side of the bonnet and the induction sounds as loud as the exhaust.
Please read my ring story:
