Author: Subject: Xflow Clutch recommendations
thepest
posted on 2/6/12 at 07:59 AM Reply With Quote
As per subject, can anyone recommend a clutch/pressureplate/thrust bearing set?
kennyrayandersen
posted on 2/6/12 at 12:32 PM Reply With Quote
bump -- I'm also interested in using a cross flow and any clutch pressure plate info would be appreciated
posted on 2/6/12 at 01:41 PM Reply With Quote
Which gearbox are you using?
kennyrayandersen
posted on 2/6/12 at 03:29 PM Reply With Quote
4-speed E type 'rocket' (or so I'm told). I'm thinking of building a Buckland B3. I know it's not a 7, but I figure there are probably quite a few folk here that know about the older Ford stuff. I'm trying to decide whether to go with the old 1.3 or 1.6 crossflow, or maybe hold out for the Ecoboost...
posted on 2/6/12 at 03:42 PM Reply With Quote
Rocket box should have a 1"x23 spline input shaft same as the type9 5 speed box . I used an early 1600 Sierra clutch kit with my type 9 and X flow IIRC.
Dave Ashurst
posted on 2/6/12 at 09:17 PM Reply With Quote
Depending on your needs and budget, AP Racing do a good range of clutch components.
thepest
posted on 4/6/12 at 04:38 AM Reply With Quote
Thanks!
