Author: Subject: ms2 extra cooling fan output
aidan46
posted on 4/6/12 at 10:15 PM Reply With Quote
Quick question.... which output do I use to use to switch my cooling fan relay ....is it the fidle or Iac or something else? Ta
coyoteboy
posted on 4/6/12 at 11:30 PM Reply With Quote
Depends how your Ms is wired up but neither the IAC nor the fidle are what you're looking for.
aidan46
posted on 5/6/12 at 08:33 AM Reply With Quote
Which output is used then for cooling fan?
big-vee-twin
posted on 5/6/12 at 08:40 AM Reply With Quote
JS0, JS2, JS11, D14, D15, D16 and FIdle - but they could already be used.
You will also need to install a transistor circuit to switch the relay coil as the MS internals cannot handle the current
see here link
and here linky
http://www.triangleltd.com
matt_gsxr
Which version of the MS board do you have?
A couple of options.
http://www.msextra.com/doc/ms2extra/build_manual.htm
http://www.msextra.com/doc/ms1extra/MS_Extra_Software_Manual.htm
Even later boards can be equipped with the means to PulseWidthModulate the fan to give variable speed (overkill but geek cool!)
Matt
Ben_Copeland
posted on 5/6/12 at 08:44 AM Reply With Quote
Google suggests you can use pin 30 fidle to control a relay to control the fan.
Ben
Locost Map on Google Maps
Enter Your Details Here
aidan46
posted on 5/6/12 at 08:57 AM Reply With Quote
I think I have the v3 version I have only purchased it withinin the last 8 months or so.
coyoteboy
posted on 5/6/12 at 07:35 PM Reply With Quote
You really need to map out all of the Is and Os you're going to use - there's no specific pin so it depends on everything else you're running. If you're running idle control using FIdle you can't use that, if you're using spark out on D14 you can't use that etc.
mtechmatt
posted on 8/6/12 at 06:19 PM Reply With Quote
For ease of use, on the V3, use the fast idle (assuming you are not using idle control) as this is essentially a transitorised relay driver already.
Advance>Output Port Settings
And select F.Idle
Matt @ M-tech
aidan46
posted on 8/6/12 at 06:21 PM Reply With Quote
Thanks that's exactly what I've done working fine now. Cheers for the help.
mtechmatt
posted on 8/6/12 at 06:41 PM Reply With Quote
No problem, if you need any help with it let me know
