Author: Subject: changing gear selection direction
b3ngy
posted on 5/6/12 at 08:36 PM Reply With Quote
Hi everyone,
The gears on my busa powered Indy are set up so that you pull to select first then push to go up the gears. I wanted to change the setup so that you push to select first and then pull to go up the gears.
I know its possible to change this and I have a couple ideas of my own but was wondering how other people have done it (in case I've overlooked something) or if there's a set in stone way of doing it.
Ideas/pictures please
Thanks, Ben
daryl
posted on 5/6/12 at 09:00 PM Reply With Quote
Where the gear shift stick is on your engine am sure if you take it off rotate it 180 then put it back on a think that will work for you
maccmike
posted on 5/6/12 at 09:02 PM Reply With Quote
Im the same, currently have two linkages connected by a bell crank. I plan to fix both links together and remove the bell crank.
b3ngy
posted on 5/6/12 at 09:13 PM Reply With Quote
Surely you need to keep the bell crank in order to keep the 90degree change of direction in the linkage?
maccmike
posted on 5/6/12 at 09:27 PM Reply With Quote
no, if I had a picture you'd understand. A straight bar with a dog leg would allow me to go forward for first and back to go up the box.
b3ngy
posted on 7/6/12 at 09:21 PM Reply With Quote
I think I understand what your saying (although a picture would help)
Daryl, I think thats the easiest solution, as I hadn't thought of that, thanks for the help
daryl
posted on 8/6/12 at 05:49 PM Reply With Quote
Well a do hope it works for you m8 let me know how you get on
b3ngy
posted on 8/6/12 at 06:08 PM Reply With Quote
Will do however might not be for a few a weeks as car is in bits! Back in to the garage i go!
daryl
posted on 10/6/12 at 01:23 AM Reply With Quote
Tell me about it m8 been about 2 years for me out soon. Been getting my first house so been spending cash on that but it's been to long now so time for it to come out to play
