Author: Subject: wtd: old laptop for megajolt
steve8274
posted on 12/6/12 at 09:14 PM Reply With Quote
hi all
i have megajolt fitted to my car, but i am unable to check if it is working correctly or to adjust it.
my laptop doesnt have the serial port required. i have tried usb adaptor but doesnt seem to work.
i have looked on ebay but there are loads of used laptops on there. too many to trawl through to see if they have serial port
can anyone give me name of one to search for or has anyone got one they no longer require
thanks
steve
tegwin
posted on 12/6/12 at 09:25 PM Reply With Quote
Hi Steve.
I have a Fujitsu Siemens Lifebook E7010 with an intel P4m processor... that has a serial port..
Pretty nice laptop actually.. I think it works but I would need to hunt out the power supply for it!
www.verticalhorizonsmedia.tv
INDY BIRD
posted on 12/6/12 at 09:26 PM Reply With Quote
Link to one I had for sale
http://www.locostbuilders.co.uk/viewthread.php?tid=164118
Bigheppy
posted on 12/6/12 at 09:47 PM Reply With Quote
http://stores.ebay.co.uk/Airedale-Computer-Recycling?_trksid=p4340.l2563
ive been considering a toughbook from here as they are so cheap. I am worried they are cheap for a reason tho
D Beddows
posted on 13/6/12 at 08:18 AM Reply With Quote
They're an incredibly low/ancient spec which explains the price - a Pentium 2 300MHZ CPU with 128mb of RAM is going to struggle doing pretty much anything to be honest. I've got a Compaq Armada M700 which cost me £20 from Ebay which has a Pentium 3 800MHZ CPU and 256MB of memory and that copes fine with Tunerstudio etc (for £20 it's actualy a lot better at a lot more things than you might expect...... it's dog slow by modern standards obviously but did I mention it was £20? lol)
[Edited on 13/6/12 by D Beddows]
mikeb
posted on 13/6/12 at 08:19 AM Reply With Quote
i think the pictures and description tell you why they are cheap, saying that most of them probably still work.
My dell doesn't have a serial but the docking station for it does, incase you already had a laptop that is compatiable with docking stations.
paulf
posted on 13/6/12 at 11:41 AM Reply With Quote
The serial to usb converters that maplin sell work ok, you just need to make sure the laptop sees it as a serial port that can be set in the megajolt tuning software.I have an old dell inspirion that I use that has a serial port its a pentium 2 650 mhz with 256 meg ram and it copes with all my tuning software.
Paul
MakeEverything
posted on 13/6/12 at 12:38 PM Reply With Quote
I got fed up with the smell of exhaust fumes (or "Garage" as its become known in our house) on the laptop, and the repairs i had to keep making to my dell, so i bought a CF-29 toughbook. Its really good and touch screen but came with absolutely nothing, no drivers or anything. took me a day to upload it all - especially as it doesnt have wifi.
[Edited on 13-6-12 by MakeEverything]
Kindest Regards,
Richard.
blakep82
posted on 13/6/12 at 12:53 PM Reply With Quote
have a check that everything's set up right on your laptop first!
while i know there are some usb converters that have problems, I bought a Lindy one, and it works fine, and i have terrible luck!
plug it in to the usb port on you laptop, check in the device manager under com & LPT to see what com port its set itself to, then go into the megajolt configurator, and set the same com port in the tools-configurator options menu
i'd be surprised if it actually doesn't work.
something to also watch out for, i've only just noticed, my laptop has 3 usb ports, each one assigns the converter to a different com port, com 4, 5, or 6. of course megajolt won't recognise it if the converter is assigned to com 6, and MJ is set to look on com4 for example.
[Edited on 13/6/12 by blakep82]
________________________
steve8274
posted on 13/6/12 at 08:46 PM Reply With Quote
thanks guys for the replies
gives me some models to look at. dont want to spend lots because it wont be used for anything else and probably only used couple of times a year i would imagine.
@blakep82, i have checked my com ports previously and was sure i set up correctly. i will check again
thanks
steve
Andybarbet
posted on 13/6/12 at 09:02 PM Reply With Quote
I have an old Dell Inspiron 7500 that im keeping for my megasquirt
It was my main laptop until about 9 months ago, bit slow but bullet proof (If a little big).
Might be worth an ebay search, should only be about £20 ish now.
