posted on 13/6/12 at 02:37 PM |
I'm not happy! [Now with photos!]
Been away for a long weekend in Scotland, and when I got back I decided that a drive round the country lanes would be nice while the weather was still
dry...
Doing quite well... until I was nearly home: came around a tight blind corner at a sensible speed, saw a van coming towards me, so braked - and the
front of the car kept on going. The wheels were on a slimy mix of mud and gravel (not even nice to walk on). Went into the front of the van at about
5 - 10mph.
The van showed no sign of damage whatsoever (plastic front), not even scuff marks.
My nose-cone is trashed, one headlight is gone, and it looks like chassis member FU2 was bent when the wheel was knocked back. When FU2 moved it bent
my steering linkage. Chassis member LA may also be bent, but I'll have to investigate further - that may only be a millimetre or two out. I
think FU2 is going to be a sod to replace as it's partly covered by the aluminium side panel (I might be able to work through the suspension arm
gaps, but it'll be tight). The suspension arms seem undamaged, but I'll strip them anyway, check them over, and repaint if they're
OK.
It's been a hectic month so far, with an 88-year-old mother-in-law in hospital in Swansea, a wedding in Scotland, and assorted other stuff going
on - I could have done without this...
[Edited on 14/6/12 by David Jenkins]
coyoteboy
posted on 13/6/12 at 02:49 PM |
Not good. Still, you're alive.
You didn't put grease on the 1144's to stop the squeeling did you?
posted on 13/6/12 at 03:17 PM |
At least you aren't hurt , better get a move on and fix it , you'll miss summer otherwise.
posted on 13/6/12 at 03:28 PM |
That's pretty much what the missus said later on...
As for missing summer - what summer?! Anyway - I drive in the winter too.
posted on 13/6/12 at 04:35 PM |
Sorry to hear that David, it's a horrible feeling!
Still, you're unhurt and capable of fixing it which is the important bit.
ditchlewis
posted on 13/6/12 at 08:08 PM |
Commiserations where did the accident happen.
once nearly happened to me, a big 4x4 came speeding round the corner and i locked up went on the verge and just missed it by 10mm.
at least you wernt hurt.
these little cars have a way of stopping you getting bored.
ditch
Dangle_kt
posted on 13/6/12 at 08:32 PM |
I guess light = fragile.
Sorry to hear of your bump, hope the car is as simple to fix as possible.
It could have been a lot worse, you could have been riding a bike, then you'd have a broke body to go with the broken bike!
posted on 13/6/12 at 09:33 PM |
On the back lane between Capel Station Garage and Bentley Church. Apparently that corner had been flooded after the torrential rain on Friday - the
water had gone, but there were a couple of inches of mud & gravel left behind that I hadn't seen. All other roads I'd driven on had
been bone dry.
If I'd been in my tin-top then the ABS might have saved a collision, but even that wouldn't have been certain. All ABS does is give you
steering control - it doesn't stop you any quicker on slippery stuff.
ditchlewis
posted on 14/6/12 at 11:39 AM |
Cuttlers lane gets like that to, the run off from the fields brings the mud onto the road.
i hope it does not take you too long to fix the car it is such a good example and a testamony to your skills.
keep your chin up and im sure you will see this as an opportunity to improve an already great car.
Ditch
[Edited on 14/6/12 by ditchlewis]
posted on 14/6/12 at 02:33 PM |
Well, I've stripped everything back and had a good look...
I think this needs replacing!
This is the only chassis member that's bent.
General view of the nose.
Close-up of the nose - I am UNIMPRESSED with the quality of work here! The gel coat is completely separate from the main substance of the GRP for
about 8" back and 6" across. I've been lucky that hasn't gone in the past.
I plan to have a go at fixing the nose - getting an "original locost" replacement will be tough, and I'd have a heap of work getting
everything else to fit to it.
mangogrooveworkshop
posted on 14/6/12 at 05:48 PM |
push it straight and put a supplementary splint tube along side it.
My chassis was toast as all the tubes in the horizontal plane had compression ripples in them
