Author: Subject: I got me a new car
StevieB
posted on 23/6/12 at 03:48 PM Reply With Quote
I got me a new car
After a bit of time trying out motorbikes, I finally decided I missed having a se7en too much and have been out this morning to look at a Westfield. End result is that I ended up doing a deal, which includes part exing my bike in so that I have the space to keep the car.
I want to do a bit of hill climbing and maybe eventually some racing so was looking for a car with as many of the required attributes as possible (ie proper roll bar, race harness, lightweight seats etc etc). Since most of these cars are no slouches no matter what the engine, that was a lower priority - I'd rather have a car well set up and learn to drive to the limits of the engine before upgrading.
This car ticks all of the boxes and also comes in the colour I wanted too (the checks are c/f vinyl and will be gone within half an hour of getting it home next Sunday and plugging the hair dryer in!).
It's currently fitted with a CVH from an XR2 which was fully rebuilt before being installed and it's running twin 40 webers at the moment. It's maybe not the most desirable of engines but it's got plenty enough poke for now and I plan to start assembling the bits for a Duratec conversion over time so that when I'm ready for more power, it'll be there to drop in.
Anyway, I love it and wanted to share the pics with those who'd appreciate them...
maccmike
posted on 23/6/12 at 04:07 PM Reply With Quote
really tidy that mate. nowt wrong with that engine either.
StevieB
posted on 23/6/12 at 04:35 PM Reply With Quote
Cheers - the ad said 'as new condition' and it really was factory fresh when I got there to see it.
There are only a few things I want to change, which are all down to personal taste than anything else and are relatively cheap/free things:
Checks need to go
Gear knob needs changing for a simple metal ball type
The ignition barrel is currently mounted under the dash below the steering wheel - don't fancy a key through the knee cap in the event of a shunt anytime soon!
PAUL FISHER
posted on 23/6/12 at 04:44 PM Reply With Quote
Thats a great looking car, you just can't go wrong with a westy, they are a good base for upgrades later on
owelly
posted on 23/6/12 at 04:54 PM Reply With Quote
Toy! Looks good Steve.
http://www.ppcmag.co.uk
StevieB
posted on 23/6/12 at 05:06 PM Reply With Quote
I shall drive it across to show it off some time!
perksy
posted on 23/6/12 at 05:32 PM Reply With Quote
Looks very tidy and in the right colour for a westy imho
CVH is a good engine and just needs regular oil changes with decent oil as they can suffer from 'sludge'
Might it be worth investing in a proper foam filter or a pair of K&N filters though instead of the gauze covers ?
StevieB
posted on 23/6/12 at 05:53 PM Reply With Quote
I had thought the same myself. There's no cut outin the bonnet either so you assume air flow is maybe a little restricted.
Seems to run well though so I'll do some research before taking saw to bonnet.
Andy D
posted on 23/6/12 at 08:45 PM Reply With Quote
Nice car.
If you're definitely going to swap the engine, it may be a good idea to leave the bonnet cutting till the new motor's in?
StevieB
posted on 24/6/12 at 09:53 AM Reply With Quote
A good point well made - a £350 error for not thinking ahead avoided!
StevieB
posted on 1/7/12 at 09:23 PM Reply With Quote
Well, I picked the car up today and it was a real hoot on the way home - I'm a very happy bunny
The car came with a couple of folders containing every receipt and invoice, original build manual and basically anything else to do with the car (right down the previous owners' WSCC membership paperwork).
Obviously first things first, the hair dryer was out and within 30 minutes of being on the drive the checks were removed and it looks a whole heap better for it:
Now obviously my mind turns to modifications.
Looking through the files, there's a rolling road print out stating max power of 116bhp at 6900 revs. There's a rev llimiter fitted to the car limiting things to 6500 at the moment (and it'll stay there for the time being so I don't blow the engine straight away by accident!). As identified earlier, the carbs don't have much in the way of a cold air feed and those horrible mesh filters can't be good (or can they?). There's not a massive amount of vertical space between the top chassis rail and the carb intakes, but there's a lot more than maybe the pic intimates.
As I'm thinking of a future (not too distant) upgrade to 16v power, most likely Duratec or Zetec, I don't want to cut a hole in the bonnet just yet.
Would anyone see a benefit in either;
1. Fit a foam filter, probably as thin as 40mm (so not pressed up against the bonnet) and duct some cold air from the front of the car to the forward end of the filter.
2. Fit some sort of plenum chamber (probably have to make sor butcher something) and again duct cold air from the front of the car into it. Something like this in form (but obviously not having a thottle body attached or being anywhere near as expensive!)
Any opinions or alternative solutions happily received!
owelly
posted on 1/7/12 at 09:30 PM Reply With Quote
Shirley, if that big scoop is sluroing cool air in, and those little triangular holes are letting it back out, there must be a bit of cool air floating over the intakes. IMHO, don't worry about it. Just wait for the upgrade....
Andybarbet
posted on 1/7/12 at 09:54 PM Reply With Quote
For my airbox im planning on using this plenum from a Nissan GTi-R.
Now to make it all fit
Ive cut the back plate out of ali, just need to drill the holes for the 4 trumpets to go through the back plate.
Airbox back plate made
It might end up being a pile of poo but it might work & it only cost me £25 from a Nissan breakers yard
matt_gsxr
posted on 1/7/12 at 10:24 PM Reply With Quote
And those pulsar/sunny gtir plenums take boost too......
Looks like a nice new car, don't rush to break it!
keith777
posted on 1/7/12 at 10:29 PM Reply With Quote
Don't call him Shirley !!
cheers Keith
