Author: Subject: temp.gauge
ed1max
posted on 2/7/12 at 09:30 AM Reply With Quote
temp.gauge
the water temp gauge on my Xflow Westfield has stopped working.the fan still cuts in.
I have checked the connections on the back of the dial and at the temps sensor all connected.
Any advice please
snowy2
posted on 2/7/12 at 12:34 PM Reply With Quote
1: temp sender U/S
2: voltage regulator U/S
3: broken wire (rare) crappy connector (not so rare)
sometimes you are the pigeon, most of the time the statue.
ed1max
posted on 2/7/12 at 12:37 PM Reply With Quote
Originally posted by snowy2
1: temp sender U/S
Than
Thanks will check it out
bmseven
posted on 6/7/12 at 12:48 PM Reply With Quote
Shorting temp sender wire on the block and temp gauge needle should rise, if not its sender U/s
BMW 7 Resource
Bures Pit anyone?
