b3ngy
posted on 4/7/12 at 08:39 PM |
Sierra steering column upper bearing
The upper bearing in my sierra steering column has completely collapsed
Does anyone know if I can get a replacement bearing (and where from) or should I just source another column??
Any help much appreciated
Ben
stevegough
posted on 4/7/12 at 08:44 PM |
Yes, there has been a few threads about this, bear with me while I find a link for you (I think it was from Simply Bearings.co.uk)
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
b3ngy
posted on 4/7/12 at 08:50 PM |
I did do a quick search but couldn't find anything......maybe I should try harder next time
stevegough
posted on 4/7/12 at 09:08 PM |
Yes, this is what you want - they post out very quickly, too.
simply
bearings
and this is what it looks like fitted.
Luego Locost C20XE.
b3ngy
posted on 4/7/12 at 09:20 PM |
Thanks for taking the time to find that for me but I already have that bearing.
Maybe I haven't explained it very well but its the bearing that sits in the column right up behind the steering wheel, it sits almost in line
with the indicator stalks.
stevegough
posted on 4/7/12 at 09:22 PM |
I didn't know there was one up there! Any photos?
Luego Locost C20XE.
RoadkillUK
posted on 4/7/12 at 09:24 PM |
I don't have one but is this the one you're looking for?
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
b3ngy
posted on 4/7/12 at 09:36 PM |
That's the lower one I think. That's the mount for mounting the column to the car isn't it?? That bearing may well be the same as
the upper one but like I said it sits further up the column towards the steering wheel.
speedygonzales
posted on 4/7/12 at 09:58 PM |
Do you mean this one:
FORD SIERRA SAPPHIRE CORTINA FIESTA TRANSIT BNIB TOP STEERING COLUMN BEARING NOS | eBay
b3ngy
posted on 5/7/12 at 05:10 AM |
Yep that's the one! Thanks
adithorp
posted on 5/7/12 at 09:26 AM |
It comes out with a few gentle taps with a drift. Be carefull you don't loose the plastiic spacer/indicator canceller or the serated
washer/spacer that go between the bearing and the steering wheel. There'll be loads of play without them... and thats often been the cause of
people thinking their bearing is knackered.
http://jpsc.org.uk/forum/
b3ngy
posted on 5/7/12 at 11:07 AM |
Thanks for the advice, I can assure you its definately the bearing as I can see loads of ball bearings floating around all over the place in there!
