Author: Subject: Locost Bits
caber
posted on 14/7/12 at 07:16 PM Reply With Quote
Locost Bits
All these bits for a Sierra based Ron Champion locost. Tried to sell as a job lot but no takers:
sierrra uprights
sierrra uprights
Ball joints
Ball joints
s/h Sierra uprights with adaptors, top and bottom ball joints (new) £ 90
Disk brakes
Disk brakes
calipers
calipers
Recon Sierra Calipers and new disks with a bit of surface rust from sitting around. £70
wishbone plates
wishbone plates
2 pairs laser cut wishbone plates £20 per pair
type 9 Gearbox
type 9 Gearbox
Type 9 gearbox with stick and chassis cross member £95
capri axel
capri axel
rear brakes
rear brakes
Capri rear axel with pair of 9" drums and backplates with seal kits £75
prop shaft
prop shaft
Propshaft 810mm overall length needs a new hardy spicer at gearbox end which is spline for type 9 £30
rims
rims
rim
rim
Set of 5 laser alloys all similar need proper refurb £65 the set
tacho
tacho
50mm Smiths tacho £25
water temp
water temp
water temp guage 50mm £15
hazzard switch
hazzard switch
Hazzard warning light switch £5
master cylinder
master cylinder
Sierra Master cylinder with reservoir and cap probably needs new seals £15
Chassis
Chassis
chassis detail
chassis detail
Ron Champion locost chassis, good standard of welding needs stripped and painted £120
rod ends
rod ends
Rod ends for Panhard rod £20
All plus postage / courier at cost but would prefer stuff picked up, particularly the big bits. Cash or Pay Pal.
Caber
blakep82
posted on 15/7/12 at 02:01 PM Reply With Quote
there wasn't a sierra based ron champion locost
i suspect these are for the chris gibbs haynes roadster perhapd?
________________________
Minicooper
posted on 15/7/12 at 02:29 PM Reply With Quote
What size disc are the front calipers for? Vented or solid?
caber
posted on 15/7/12 at 03:20 PM Reply With Quote
@blakep82, before chris gibbs book came out there were rather a lot of Ron Champion locosts built with sierra doners due to lack of Escorts. Mine has a real mix of parts including sierra engine, gearbox and other things. As Cortina uprights are also rare Sierra ones were also sometimes used. You could use bits to build a Chris Gibbs roadster but chassis and back axle would not work
@minicooper, the calipers and disks are a set. The disks are vented and sierra size to fit the uprights, next time I gp to lock up I will measure but this may not be until next weekend.
Caber
Minicooper
posted on 15/7/12 at 04:07 PM Reply With Quote
Thanks Caber, whatever size the sierra calipers/discs turn out to be, I believe either 240mm or 260mm is usual sierra sizes, did you try them for fitment inside the laser alloys which I think are 13" like my current wheels are? This information would help me either way if you did
caber
posted on 22/7/12 at 12:40 PM Reply With Quote
Disks 255 dia. And do fit in 13" wheels with calipers
Caber
caber
posted on 1/8/12 at 09:13 PM Reply With Quote
Does nobody want any of this stuff? Is anyone building Locost sanymore?
Caber
caber
posted on 17/8/12 at 08:15 PM Reply With Quote
bump?
