pekwah1
posted on 16/7/12 at 03:25 PM |
Indicator/hazard wiring (sierra)
Hi Guys,
I'm trying to adapt my wiring on my striker to work for the sierra switches.
I'm getting a bit confused as there is a slight mis-match of wires, and the striker loom seems to cater for old school rocker switches rather
than a column switch.
Anyway, these are the wires i have on my loom:
So i'm guessing i should also have two flasher units?
However i've read that you should be able to do it with just one with a sierra switchgear?
And this is the wiring for the sierra switches:
The one wire i am confused by is PIN15.
This is a positive on the loom, but on the switchgear is a negative, i'm guessing this is because it's a switched negative?
Oh i'm very confused, anyone who can put this into english will win a medal!
loggyboy
posted on 16/7/12 at 04:04 PM |
I have a raw loom diagram at home that shows both raw and sierra colours, can look this eve for you if you like.
It was also mentined on here that ford switched between + and - switched feeds, cant recal which way round it was though!
[Edited on 16/7/12 by loggyboy]
Mistral Motorsport
Irony
posted on 16/7/12 at 04:05 PM |
I am more or less at the same point in my wiring. I just couldn't wrap my head around the diagram and the continuity circuit results I was
getting from the multimeter when switching the levers. In the end I have just connected it as I see fit for the sides, dip and mains. However the
indicators and hazards are my next task.............. So I will be watching this thread.
pekwah1
posted on 16/7/12 at 04:07 PM |
Cheers loggy, although i have the wiring thing for the raw loom and the sierra switch as per my post, it just doesn't make too much sense to
me...
At the moment i only have one flasher unit so i'm wondering if i actually need another one, and what i'm supposed to do with pin 15!!
loggyboy
posted on 16/7/12 at 04:14 PM |
me...
Lol just realised looking back a few posts it was you querying the switched live etc!
Does your raw loom have both colours listed?, ie the colour of the raw loom and the colour that should compare to the sierra loom? as your scan doesnt
show it?
Mistral Motorsport
pekwah1
posted on 16/7/12 at 04:19 PM |
it does on some stuff i.e. ignition etc but no not for the lighting/indicators etc.
Does yours?
Maybe that would be useful if so....
loggyboy
posted on 16/7/12 at 04:31 PM |
I will check and get back to you.
Mistral Motorsport
Not Anumber
posted on 16/7/12 at 07:00 PM |
Are there any alternative diagrams for the sierra wiper and headlight pin outs ? I'm in the process of retro fitting the extra stalks at
present to replace the existing dash mounted switches. Theres a short length of the donor loom attached to the plugs but several of the wire colours
are in different positions to the diagram above . Could anyone check this please in a Sierra manual if they have one handy.
loggyboy
posted on 16/7/12 at 08:14 PM |
Sorry, you were right, the equivelent colours are just for some the ignition etc.
Mistral Motorsport
