New Topic New Reply
Author: Subject: Control cable problem
smart51
posted on 16/7/12 at 04:57 PM Reply With Quote
I've just fitted a long throttle cable (3.2m) but it binds when I try to pull it. The throttle turns by hand freely and the (disconnected) cable pulls through easily enough. When it's all connected, it just won't pull. Is there a limit to the load and length of these things?
austin man
posted on 16/7/12 at 07:55 PM Reply With Quote
Are you sure its not dragging on something or kinked. Make sure the clevis pin it attaches to can swivel freely as well
Mal
posted on 16/7/12 at 08:20 PM Reply With Quote
I use a 3m long cable without the problem you describe.
Does yours have a plastic liner?
smart51
posted on 16/7/12 at 08:30 PM Reply With Quote
There are no kinks. Thereis a 180 degree turn but it is about 20cm dia. It doesn't have a plastic liner though. Does that make much difference?
Jon Ison
posted on 16/7/12 at 08:43 PM Reply With Quote
As your pedal got a return spring on it or are you relying on the throttle return springs to pull the pedal up ?
I used Teflon lined cables, slippy as hell.
New Topic New Reply
