Author: Subject: A stroke to many ?
Jon Ison
posted on 24/7/12 at 11:45 AM Reply With Quote
A stroke to many ?
5 stroke
scudderfish
posted on 24/7/12 at 12:00 PM Reply With Quote
Principle of operation
The 5-stroke concept engine utilises two fired cylinders (High Pressure - HP) operating on a conventional 4-stroke cycle which alternately exhaust into a central expansion cylinder (Low Pressure - LP), whereupon the burnt gases perform further work. The LP cylinder decouples the expansion and compression processes and enables the optimum expansion ratio to be selected independently of the compression ratio.
Sounds a bit like a triple expansion steam engine (well double expansion in this case)
The Shootist
posted on 24/7/12 at 03:08 PM Reply With Quote
Waste of time...
That's a 50% increase in part count for a specific fuel efficiency no better than a CVCC Honda engine.
