Author: Subject: GSXR Throttle Body Vacuum Pipes
Cheffy
posted on 29/7/12 at 09:40 PM Reply With Quote
Evening all,
Been doing some research on here to figure out where the various vacuum pipes on my throttle bodies fit. As in title, they are GSXR 600 TB's, and are going on a 2.0L Zetec black top via an ST 170 manifold, using Megasquirt (V3 board and MS I processor).
Firstly, there are 4 vacuum pipes - one from each TB that join into 1. I gather these connect to the vacuum tube back to the MS. Is that correct?
Secondly, on the 3rd TB from the left there is one pipe on it's own. Where does that go to?
Thirdly, there is a vacuum pipe from the bottom of the fuel pressure regulator. Am I right in thinking that I can just leave this disconnected?
Thanks in advance for any assistance,
Martin.
Farts are like Rock'n'Roll. You love your own but you hate everybody else's. Lemmy, Motorhead.
Andybarbet
posted on 29/7/12 at 09:45 PM Reply With Quote
I was going to ask the same question, ive got gsxr600's on a silvertop.
Lets see what the collective say ??
AntonUK
posted on 29/7/12 at 09:49 PM Reply With Quote
the pipes all tied together goto the MS
the random pipe on cyl 2 can be blanked
(i used these: NISSAN SUNNY PULSAR GTI-R INTAKE MANIFOLD VACUUM PORT BLANK OFF CAPS BUNG PLUG | eBay
the reg vac connector is left open
EDIT: Link update
[Edited on 29/7/12 by AntonUK]
Build Photos Here
Cheffy
Agreed. Gotta love the collective!
Cheffy
posted on 29/7/12 at 09:51 PM Reply With Quote
EDIT: Link update
Wow, thanks for the quick response.
Martin.
Andybarbet
posted on 29/7/12 at 10:04 PM Reply With Quote
Spot on
I picked up some 4mm blue vacuum pipe for £2.34 from here:
Silicone Vacuum ASH Hose Pipe - Silicon Water Air Coolant Dump Valve Radiator | eBay
I was going to bung with one of these:
SILICONE HOSE INTAKE VACUUM STOP END CAP BUNG PLUG 4mm x 4 *BLUE* | eBay
GeoffT
posted on 30/7/12 at 08:17 AM Reply With Quote
Also be aware that you'll need some restricters in the vac lines, otherwise you'll end up with a very noisy signal which will give you all sorts of issues with ms (random ae triggering, etc).
From memory I think I used a 0.6 mig tip pushed into each of the four vac lines, (I may have also fitted one into the single line to ms) but it will vary with individual installs. It is possible to overdo it though, which will over damp and slow the map signal, this too can cause problems.
Best bet is to monitor the map signal when you have it running and fiddle until you get it reasonably clean without undue lag.......
Geoff.
stevebubs
posted on 30/7/12 at 12:56 PM Reply With Quote
Geoff.
I think some people have used old push bike emergency inflation cylinders drilled and tapped as a way in which to smooth out the vacuum pulses.
stevebubs
posted on 30/7/12 at 12:57 PM Reply With Quote
PS TPS sensor wiring should be as per my photo archive
Gsxr750 TPS; A=+5v ; B=Signal ; C=GND
Cheffy
posted on 2/8/12 at 08:59 PM Reply With Quote
Sorry, haven't checked in for a few days. Thanks for the recent replies.
Martin.
BaileyPerformance
posted on 2/8/12 at 09:00 PM Reply With Quote
Originally posted by Cheffy
Evening all,
Martin.
You do not need the vac signal for ms assuming your engine in NA.
You need to map your engine on throttle position only Alpha N mode. Job done! We have mapped 20 plus zetecs on throttle bodies and always used tps instead of map.
Block off all vac pipes, leave fuel pressure reg open.
Let me know if you need any help,good luck with your project!
Cheers dale.
