Author: Subject: Made me chuckle
posted on 1/8/12 at 10:36 PM Reply With Quote
Made me chuckle
Rotting about on YouTube I found this, which for some reason just made me chuckle...
http://www.youtube.com/watch?v=xvReVRsk9EM&feature=related
maccmike
posted on 1/8/12 at 10:50 PM Reply With Quote
why why why would you do it! hahaha
if thats got 450bhp ill show my arse in m&s's window!
morcus
posted on 2/8/12 at 02:29 AM Reply With Quote
This one is funnier.
FWD vs RWD.
The Shootist
posted on 2/8/12 at 04:34 AM Reply With Quote
Maybe optimistic but close...
I'm familiar with the builder from the TDI forums.
He is running a 1.9L ALH with a Cummins inline pump, and an 82mm turbo. Somewhere around 70psi of boost.
He works in a shop that builds supped up American diesel pickups... 1,ooo hp pull trucks.
His biggest trick is a custom made cast iron head and a block girdle that sandwiches the block between the head and re-enforced oil pan using external bolts.(stock ALH engines will lift the heads and blow the gaskets at 30 psi or so)
Biggest weak point....transmissions
posted on 2/8/12 at 05:21 AM Reply With Quote
Good to get some inside info on it.
Partly I like it because it's something different to see.
As you say FWD transmissions aren't generally built for monster BHP, let alone the torque it must be generating!
Slimy38
posted on 2/8/12 at 08:23 AM Reply With Quote
Not sure the exhaust should be pointing out the bonnet though (if that's what it is?), it makes it look like a diesel train!
jossey
posted on 2/8/12 at 03:54 PM Reply With Quote
Yes that is funnier :-)
quote]Originally posted by morcus
FWD vs RWD.
David Johnson
loggyboy
posted on 2/8/12 at 03:57 PM Reply With Quote
Dont know why but this spung to mind after watchting that first one
[Edited on 2-8-12 by loggyboy]
Mistral Motorsport
maccmike
posted on 2/8/12 at 04:11 PM Reply With Quote
thats crazy lol
RK
posted on 2/8/12 at 04:40 PM Reply With Quote
That last one was brilliant. Too bad he couldn't get it to drive somewhat straight. More people have to build these sorts of things.
