New Topic New Reply
Author: Subject: Cooling pipe swager
theprisioner
posted on 5/8/12 at 09:32 AM Reply With Quote
Cooling pipe swager
I came across what I think is a unique tool made by a company called Kingley.
Kingley swager
Kingley swager
It swages metal pipes for cooling system rubber hoses. The chap that introduced me to them had several examples but as luck has it not one the size I wanted.
I have search the web but cannot even find out who Kingley are, I guess they went out of business a long time ago!
However with my trusty Myford I was able to make one the right size so I enclose the drawing should it be of use to others.
Kingley lookalike
Kingley lookalike
I have the Turbo CAD file if you want it.
HowardB
posted on 5/8/12 at 03:53 PM Reply With Quote
that looks most excellent, and a neat way of doing it. I made something a little more agricultural,...
diy tool1
diy tool1
for flaring ali tube
Interesting though,.. your solution will be much better for smaller diameter tube,..
thanks for sharing
Howard
posted on 5/8/12 at 04:20 PM Reply With Quote
Do the holes for the ball bearings not need an internal taper?
daviep
posted on 5/8/12 at 04:59 PM Reply With Quote
When I made may cooling pipes (10 years ago) I made a small tool up using a hydraulic quick connector, basically all it need was the locking collar removed, the body turned down to fit in the pipe and a tapered expander for the balls.
From this
To this
rdodger
posted on 5/8/12 at 05:25 PM Reply With Quote
They have been around since WW2 at least. Available from here.
http://www.earls.co.uk/earls/accessories/tools/beadingtools.html
HowardB
posted on 5/8/12 at 06:45 PM Reply With Quote
Very interesting, not ever seen them before, to paraphrase, there is nothing new under the sun,...
Howard
theprisioner
posted on 5/8/12 at 10:26 PM Reply With Quote
Very interesting!
No 28mm - 1.102" but I think I may order some of the other sizes.
The Old Tool Shed says:
........thanks fr your email, I cant be of help at the moment, we dont have any in stock. I have come across them on the past though, I will keep my eyes peeled for you and let you know, although the one in the photo you made looks damn good!
I like praise like that!!!
rdodger
posted on 6/8/12 at 07:46 AM Reply With Quote
I got mine from here a few years ago.
http://www.chicagoconnection.us/index.php?main_page=index&cPath=3_930_960
New Topic New Reply
