<<  1    2  >>
Author: Subject: What to take to the IVA test tomorrow
Davegtst
posted on 12/8/12 at 11:22 AM Reply With Quote
I've got my IVA tomorrow and i'm getting all the bits ready today so i can hook the trailer up in the morning and go. So far i have packed a load of tools, spare trim and a few other bits and pieces. Is there anything else people have found they needed to take?
loggyboy
posted on 12/8/12 at 11:29 AM Reply With Quote
A copy of the very latest IVA manual to check the tester knows what hes talking about?
I havent done IVA yet, but I will also take - Cable ties, any specialist tools, super glue, pen and paper, camera.
Mistral Motorsport
ali f27
posted on 12/8/12 at 11:45 AM Reply With Quote
Your car good luck not as bad as you think
stevegough
posted on 12/8/12 at 12:32 PM Reply With Quote
The good wishes of everyone on LCB?
and Loggyboy - you aren't allowed to take photos in the VOSA place (unless you do it 'discreetly' like I did!)
[Edited on 12/8/12 by stevegough]
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Andybarbet
posted on 12/8/12 at 12:42 PM Reply With Quote
Good luck tomorrow
carlknight1982
posted on 12/8/12 at 01:07 PM Reply With Quote
make sure that all your fluid levels are full oil brakes fuel, take all your build photos and as much proof as you can, my anchor points for my belts were not visible but the photos were good enough proof so that i didnt have to remove a panel to show it, same with the tank earth.
Logic will get you from a A to B
Imagination will take you everywhere.
ali f27
posted on 12/8/12 at 01:22 PM Reply With Quote
have a slow quiet look around your car and check things against what you know from iva manual most peple get caught out by somthing really simple grip on brake pedal etc and remember the tester is not the enemy just doing his job if its right ok if its not fail dont need to kiss his arse but be friendly and positive can make a bit of difference if you need to do some fettling
GOJO
posted on 12/8/12 at 02:10 PM Reply With Quote
Some clear silicone and zip ties
Daddylonglegs
posted on 12/8/12 at 02:50 PM Reply With Quote
I took a good selection of tools, bolts, nuts, washers, Tape, tie-wraps, screwdrivers, trim.
And make sure you have a full tank of fuel, that was the second question my tester asked. Apparently they can fail you for not having a full tank Something to do with weights I think.
Most of all, GOOD LUCK!! Hope it all goes well
gavin174
posted on 12/8/12 at 02:54 PM Reply With Quote
brown envelope stuffed with used twenties........
stevegough
posted on 12/8/12 at 04:41 PM Reply With Quote
Proof of engine age?
Luego Locost C20XE.
robinj66
posted on 12/8/12 at 04:50 PM Reply With Quote
gaffer tape & superglue - comes in handy for all sorts of things
and good luck
Toprivetguns
posted on 12/8/12 at 05:17 PM Reply With Quote
Good luck mate, whereabouts is your test ?
Only drive as fast as your angel can fly... !
Davegtst
posted on 12/8/12 at 10:39 PM Reply With Quote
Cheers for the tips and support guys, I think I have half my garage packed in the van now. I've only just got in from work and I im leaving for yeading at 6am so I better try and get some sleep in.
ashg
posted on 12/8/12 at 11:54 PM Reply With Quote
my advice is to leave the iva manual in the car. only get it out if you have an issue with a decision the tester makes. if you go in with it they will have their guard up from the off.
been there done it several times, take the chilax route its much easier.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
L5W
posted on 13/8/12 at 06:46 AM Reply With Quote
good luck for today
Lee
http://l5w-mk-indy-zetec.blogspot.com/
Davegtst
posted on 13/8/12 at 09:07 AM Reply With Quote
This is terrible
loggyboy
posted on 13/8/12 at 09:11 AM Reply With Quote
The waiting or the result?
Mistral Motorsport
Davegtst
posted on 13/8/12 at 09:15 AM Reply With Quote
The testing. Think I'm not far from the end now.
MikeFellows
posted on 13/8/12 at 09:25 AM Reply With Quote
If I where the IVA tester and you turned up with the book trying to tell me my job, your car would need to be 100% on everything for it to pass
loggyboy
posted on 13/8/12 at 10:17 AM Reply With Quote
I didnt mean to say you should wave it under his nose and question everything!
Personally if he saw you had a copy (with your paperwork, not being scrutinised thoughtout the inspection!) it may even show him that you have actually bothered to download, read and use it during the build.
Either that or as AshG said, just have it there for a reference in case something crops up that you were sure you had done to the manual. More to confirm that you were wrong rather than he was!
Mistral Motorsport
MikeFellows
posted on 13/8/12 at 10:41 AM Reply With Quote
ahh sorry, I misunderstood, I thought you meant to question the wording etc..
loggyboy
posted on 13/8/12 at 10:45 AM Reply With Quote
Whilst it would be quite fun if you could fun, sadly as you know, they are judge, jury and executioner! I would expect you could contest through official channels post decision I doubt you would get far.
Mistral Motorsport
Davegtst
posted on 13/8/12 at 10:58 AM Reply With Quote
This tester is the biggest jobsworth prick I have ever met I'm my life.
loggyboy
posted on 13/8/12 at 11:02 AM Reply With Quote
I hope hes not a member!
Mistral Motorsport
<<  1    2  >>
