FuryRebuild
posted on 14/8/12 at 02:27 PM |
new wishbones to avoid rod-end in bending- this is getting expensive
Wow - in order to do this right and have the spherical bearings captured and avoid rod-end-in-bending, it's starting to get a little expensive.
However, I'm going to motor on.
I've got my 5/8 spherical bearings, bearing cups and cir-clips from McGill motorsport - great service. £40, give or take.
reamer to take my upright out to 5/8 from the tapered hole to an accurate 5/8" hole: £40
5/8" socket headed cap screws, 4" length: £28 for two. I could have got bolts at the same length, but they were £24 (both prices included
postage and vat).
Various others, about £30 to complete the manufacture.
However, I'll have a pair of wishbones, done properly, engineered well for £75 each, and yes, I'd stake my life on them.
The bolts were the proper expensive part, and I've ended up having to go stainless from westfield fasteners to get the sizes I want (3"
length isn't enough to go through the misalignment spacers, bearing and upright whist giving 2 turns of the thread for safety.
[Edited on 14/8/12 by FuryRebuild]
www.furyrebuild.co.uk
SausageArm
posted on 14/8/12 at 02:36 PM |
It's urprising how costs add up when doing anything to your car.
Do you have any photos of the wishbones, before/duting/after?
posted on 14/8/12 at 02:38 PM |
5/8" sounds huge, does it really need to be that large?
Mr Whippy
I don't like the idea of stainless bolts used for suspension, they should normally be 8.8 grade steel ones
FuryRebuild
Hi SausageArm
Firstly, I must complement you on such a great name.
I have learned that everyone here is picture-hungry, so I will provide. I'm waiting until I get the bolts in before I start putting pictures up,
and I have some new stepped-hole brackets I need back from the laser-cutters first to allow me to make the suspension height adjustable.
Mark
FuryRebuild
posted on 14/8/12 at 02:51 PM |
My Whippy
You raise an interesting point. I've ordered a2-70 bolts, with a tensile strength of 700N/mm2 and yield strength of 450N/mm2.
This compares with 828 and 635 respectively for 8.8.
I'm going to need to go away and see if I'm comfortable with the numbers. I can't get what I need in either steel or A4-80. If you
know someone who's got a supply, I'd love to know.
Mark
40inches
posted on 14/8/12 at 03:07 PM |
quote: Originally posted by FuryRebuild
My Whippy
Mark
Couldn't you use 5/8' to 1/2' Rose Joint Reducers,High Misalignment | eBay and 1/2" bolts?
1/2"x4" S grade £12 for 25
here
[Edited on 14-8-12 by 40inches]
phelpsa
posted on 14/8/12 at 03:16 PM |
My Whippy
Mark
The holes in the uprights are 5/8 by the sounds of it.
I would (personally, i am not recommending it to you!) be ok using 5/8 stainless bolts as they are so massively over specced. However fatigue of
austenitic stainless is a bit of a difficult one IIRC.
FuryRebuild
posted on 14/8/12 at 03:20 PM |
The problem is in the upright tapered hole. It starts out at 5/8 and goes down to 1/2, so if I went with 1/2 (my first choice) then it would be
rattling around in there.
5/8 was the first size I could come across that would give me clean location and not end up with it rattling around.
Mark
40inches
posted on 14/8/12 at 03:35 PM |
Seem to be £1 each here not tried to buy them though
posted on 14/8/12 at 03:58 PM |
Using even high grade stainless bolts in this application would worry me.
FuryRebuild
posted on 14/8/12 at 04:01 PM |
Hi BritishTrident
A4-80 are similar to 8.8. I'm stuggling to find them as well at the moment; it's a little tricky at work right now.
meh - saying that, I'm not going to stick with my original wishbones, the force goes around too many corners.
FuryRebuild
posted on 14/8/12 at 05:05 PM |
Right then
After all the good advice, I've sent the stainless bolts back. I am assuming that everyone here who has said "don't do that -
stainless is wrong in that application" are doing so not because of the strength in the bolt, but because stainless has a different fatigue
characteristic to 8.8 alloy. Or are you doing it because you remember the specification?
Either way, having a wheel fall off because one didn't listen isn't a funny thing.
I've found malpas tractor parts, who sell 8.8 rated bolts at the right spec and length for peanuts, and
here's the
link
Mark
eddie99
posted on 14/8/12 at 05:08 PM |
Don't want to scare you but McGill Motorsport rod ends are not great
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
FuryRebuild
posted on 14/8/12 at 05:10 PM |
Let's see how I do.
I tend to take them off and check them every 6 months anyway - if they're getting too stiff or the surfaces are pitting, I scrap them.
phelpsa
posted on 14/8/12 at 05:26 PM |
That's not the experience I've had. What are you comparing them to and in what application?
Here's the spec sheet for the McGill 'Ultra hight performance' rod ends:
http://www.qa1.net/qa1_motorsports/drag-and-street/rod-ends/endura-racing-series/xm-series-chromoly-steel.html
[Edited on 14-8-12 by phelpsa]
eddie99
posted on 14/8/12 at 05:30 PM |
Just I've bought of rally design, auroras from specialist bearing places, then McGill
I bought the high grade from McGill and were already not very loose and quite stiff.
However McGill are cheap, much cheaper than buying the auroras.
+ I have friends in various differnt race cars that have had a fair few McGill rodends break on them
phelpsa
posted on 14/8/12 at 06:23 PM |
Eddie,
All spherical bearings should start off with some break out torque, this is what you felt as 'stiffness'. This is quite high in the qa1
bearings due to the liner design. They loosen up in a short period of time.
I suggest that these friends have not specced the bearing properly. If they have replaced a higher spec, more expensive bearing with one of these then
more fool them! Have they taken up their issues with qa1, and checked that they were operating within their specified load limits?
owelly
posted on 14/8/12 at 06:25 PM |
As is the way of Locostbuilders lately, I'd like to point out something you've done wrong. Something I wouldn't have done. And/or
something that is downright dangerous. I can't think of anything just yet but I'll give it some thought....
http://www.ppcmag.co.uk
Mr C
posted on 14/8/12 at 07:01 PM |
+1 on that, though to be fair to Eddie he is very well intentioned, perhaps other threads are clouding the issue as you are right about the
negative feedback currently evident lately. I'm currently planning a suspension conversion for my next project and am very interested n the
Current issues on suspension design and rod ends etc, though it is very difficult to sift out the helpful and less helpful responses, the downright
destructive ones are pretty easy. Though entertaining to an extent they are getting boring at best and go against the helpful nature of this forum and
its good reputation at worst.
I'm developing some front suspension taken from a well proven sportscar for use in front and back applications in a lmp type design. I was gong
to post for advice pointers etc, not sure that I will now, perhaps I'll post up the aftermath of a rod end failure then no doubt I'll have
someone posting up "if only he asked us I could have told him it was sh!te and he'd kill himself".
I don't know the answer to the current way of the forum, perhaps in time things'll settle down again, anyhow best of luck to the op and
please keep us informed of progress.
Girl walks into a bar and asks for a double entendre, so the barman gave her one
FuryRebuild
posted on 14/8/12 at 07:19 PM |
Mr C
This is indeed turning into a good thread.
As is often the case, some get it, and some don't when it comes to the mods one makes. There was a really mixed set of comments to the spider I
made for my engine bay, but quite a few understood the need to amke it stiff, and the engineering involved to get it there.
In this thread I've had great responses, and they've made me change my approach (i.e. not go for stainless bolts, although I had to work
out why myself).
I now know about bolt head markings, steel alloy ratings and other things. I'll worry when everyone tells me i'm brilliant.
I think this has been a lively thread, and I wouldn't even mind a good argument if done politely.
Take a look at my blog (furyrebuild.co.uk) and you can see the mods I've made.
I'm going to continuously publish them here as well even though it can mean filtering a little chaff; I feel I owe it to the community for the
help I get, and support when I've designed something correctly.
Mark
owelly
posted on 14/8/12 at 08:25 PM |
Incidentaly, I wasn't aiming my previous post at anyone in particular.......
