Author: Subject: Rear brakes for 13" wheels
madrallysport
posted on 15/8/12 at 07:43 AM Reply With Quote
Guys i have a aries car, i was wondering what brakes cal's are you using on the rear of cars that fit under 13" wheels.
I had cal's but they are non handbrake ones, i now need handbrake type ones.
the car is IRS at the back running.
Thanks in advance.
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
renetom
posted on 15/8/12 at 08:55 AM Reply With Quote
brakes
Hi
Drums on the back are perfectly adequate for such a light car
And possibly lighter than discs , our indy failed the first IVA because the rears were locking up
before the fronts & we have Willwood 4 pot callipers on the fronts, std sierra drums on the rear
We had to fit an auto bias valve on the rears. passed 2nd time ok.
Good luck.
René
phelpsa
posted on 15/8/12 at 09:02 AM Reply With Quote
I'm using peugeot 205GTI calipers all round on my Aries and they work to good effect! Small, mostly ali, half decent handbrake mechanism (not that I have it connected).
Wadders
posted on 15/8/12 at 09:53 AM Reply With Quote
+1 for pug calipers
]Originally posted by phelpsa
posted on 15/8/12 at 10:36 AM Reply With Quote
XR4i 10" drums on mine, completely fill the wheels.
SausageArm
posted on 15/8/12 at 11:33 AM Reply With Quote
Wilwood handbrake calipers but I forget what kind of discs they are, I got the discs from Mac#1 Motorsports.
and this is how they look behind a 13" Team Dynamic Pro Race 1.2
snakebelly
posted on 15/8/12 at 11:54 AM Reply With Quote
What did you do for a mounting bracket using the wilwoods?
CNHSS1
posted on 15/8/12 at 05:40 PM Reply With Quote
any pics of the Pug rear setup please?
CNH
Wadders
posted on 15/8/12 at 06:21 PM Reply With Quote
Here you go
CNH
SausageArm
posted on 15/8/12 at 09:08 PM Reply With Quote
phelpsa
posted on 15/8/12 at 09:17 PM Reply With Quote
CNH
Here's my version:
It was far from easy, but very neat and light.
CNHSS1
posted on 15/8/12 at 10:01 PM Reply With Quote
Cheers, good solution
Lew The Machine
posted on 6/11/13 at 07:59 AM Reply With Quote
Hi guys,
Sorry to revive an old thread but this is where the search button led me!
Just started looking at the rear brakes on my build and finally bit the bullet and decided to move away from sierra drums (even threw my back pates away to make me find a solution!)
phelpsa - i think ive just read the thread of your build (if its not you then they're identical haha) on RR but as im not a member there i thought id post the question here instead... the brackets you used to mount the 205 calipers? do you still have the cad files used to cut them? its such a neat setup!
the other problem is that im using haynes roadster style rear uprights, has anyone combined that caliper with haynes parts before and did it end well?
cheers
Lew
ITS FINE! i welded it!
phelpsa
posted on 6/11/13 at 09:44 AM Reply With Quote
Originally posted by Lew The Machine
Hi guys,
cheers
Lew
I'm not sure I do (moved PCs a couple of times since then!). I'll have a look tonight.
Lew The Machine
posted on 6/11/13 at 09:52 PM Reply With Quote
Any joy?
I'm also struggling to find the mk5 escort discs you used, all the ones I found seem to be much lower offset!?
Thanks again!
Lew
ceebmoj
posted on 7/11/13 at 12:26 AM Reply With Quote
Originally posted by Wadders
Here you go
CNH
what disk and bell are you using?
phelpsa
posted on 7/11/13 at 09:50 AM Reply With Quote
Any joy?
Thanks again!
Lew
Unfortunately not! It may be on my old laptop at my parents house, will try and remember to check when I next return!
As for the disc, i went to the local motorfactors and had a flick through their catalogue with all the dimensions in. Alternatively, have a look on Brakes International, or Westfield used to sell them.
Lew The Machine
posted on 7/11/13 at 02:17 PM Reply With Quote
Oh well! It was worth an ask... Thanks anyway!
Looks like im going on a trip to the scrap yard friday afternoon! see if i can get a complete setup with cables etc, maybe even get a disc off an old escort if they have one in!
phelpsa
posted on 7/11/13 at 10:42 PM Reply With Quote
Looks like your luck is in! I was searching for a CAD model this evening and stumbled across the caliper bracket drawing! What's your email address?
Lew The Machine
posted on 7/11/13 at 11:07 PM Reply With Quote
Haha awesome! I'll pm you my email address now!
