Author: Subject: bending 1/2" round tube
vonmoogen
posted on 19/8/12 at 08:16 PM Reply With Quote
Any suggestions of how best to bend 1/2" round tube. Needs bending over a radius of 12". Don't have access to a ring roller so thats out. Any other suggestions?
Cheers Rob
jossey
posted on 19/8/12 at 08:21 PM Reply With Quote
Take it to a exhaust place locally and they will bend it cheap I got my roll bar bent for £10.
Hope that helps.
David Johnson
daviep
posted on 19/8/12 at 08:24 PM Reply With Quote
What wall thickness?
vonmoogen
posted on 19/8/12 at 08:44 PM Reply With Quote
It's 18 swg. Just noticed for some reason its showing up as 12 inch not 0.5 inch on main page.
HowardB
posted on 19/8/12 at 08:54 PM Reply With Quote
I bent mine round an old sierra disc clamped to a bench,... worked a treat,...
hth
Howard
vonmoogen
posted on 19/8/12 at 08:59 PM Reply With Quote
I had thought of cutting a former for the radius out of MDF. Anyone tried it?
HowardB
posted on 19/8/12 at 09:37 PM Reply With Quote
I thought that, but the solid steel brake disc was just the right size, and as it was a vented disc it had a handy groove that the pipe could sit in.
sorry no pic,.. but a block of wood as the end stop, and the disc both clamped to the bench,.. 2 mins later,... hey presto!
Howard
daviep
posted on 19/8/12 at 09:50 PM Reply With Quote
I'm guessing he probably doesn't have a 24" brake disc lying aroung
spiderman
posted on 19/8/12 at 09:54 PM Reply With Quote
I have not tried it myself, but I have heard of others doing it successfully.
Spider
renetom
posted on 20/8/12 at 06:51 AM Reply With Quote
bend
Hi
What about a plumbers pipe bender they are normally for 1/2" & 3/4" pipes.
Where are you ?
I have one if your not too far away.
Good luck
René
vonmoogen
posted on 20/8/12 at 07:57 AM Reply With Quote
Rene thanks for the offer but I'm a bit far away in Inverness!!!
With the plumbers pipe bender can you make gentle radii? I thought they were more for acute angles.
renetom
posted on 20/8/12 at 04:21 PM Reply With Quote
bends
Hi
You can get pretty much whatever you want , you just move it round the former.
I've made some weird & wonderful pipe shapes with mine.
Good luck
René
