Author: Subject: Sierra upright secondary fixing
rdodger
posted on 1/9/12 at 12:31 PM Reply With Quote
I am lead to believe that the mushroom insert in a Sierra upright needs a secondary fixing to pass IVA. Any one got pics of what they have done?
SteveWalker
posted on 1/9/12 at 12:39 PM Reply With Quote
Is that only if the spring/damper is attached to the bottom arm? If they are attached to the top arm, surely it's no different to a McPhearson strut, which do not have a secondary device?
deezee
posted on 1/9/12 at 12:42 PM Reply With Quote
A McPhearson Strut is bolted to the upright, not clamped. Its a requirement on all vehicles for a positive fixing method. Clamping the top wishbone mushroom insert isn't suitable as it could work loose. It needs to be bolted into place.
Minicooper
posted on 1/9/12 at 12:45 PM Reply With Quote
They do have a secondary fixing the bolt goes through a hole in a plate welded to the upright, you can see one of them in this picture
SIERRA / SAPPHIRE 2WD RWD FRONT STRUTS + SPRINGS 1.8CVH | eBay
[Edited on 1/9/12 by Minicooper]
RichardK
posted on 1/9/12 at 02:05 PM Reply With Quote
Yep a few in my gallery, use the banner below.
Rich
Gallery updated 11/01/2011
posted on 1/9/12 at 02:39 PM Reply With Quote
All that is require is drilled tapped hole for a locking screw.
Minicooper
posted on 1/9/12 at 02:45 PM Reply With Quote
Found a picture
snapper
posted on 1/9/12 at 03:10 PM Reply With Quote
We didn't do it on 3 cars that passed IVA.
I eat to survive
I drink to forget
whitstella
posted on 1/9/12 at 03:41 PM Reply With Quote
hi
hi
mine passed iva (about 5 weeks ago) without anything too, depends on the day i suppose.
cheers steve
stevegough
posted on 1/9/12 at 04:06 PM Reply With Quote
Originally posted by Minicooper
Found a picture
That picture looks familiar!!
Yes, it is my car, and it was a fail point on my IVA. I drilled through, and fitted a bolt with a nyloc on the other end. (it was dammned tight to get the nut on, and I had to tighten it with pliers - the spanner wouldn't go on. - As british trident said, drilled and tapped may be easier.
Here's a pic....
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
ReMan
posted on 22/9/18 at 04:47 PM Reply With Quote
istr that it was previously ok for sva, but iva required the extra fixing
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
CosKev3
posted on 22/9/18 at 07:30 PM Reply With Quote
Been on the beer?!?
2012 this thread........
ReMan
posted on 22/9/18 at 07:41 PM Reply With Quote
Been on the beer?!?
Yes and no!
A beer or two tase been, but the error was replying on this thread, not on th ecurrent one it is linked from
Now when i paste this will the internet break?....................
http://www.locostbuilders.co.uk/viewthread.php?tid=213460
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
CosKev3
posted on 22/9/18 at 07:58 PM Reply With Quote
