Author: Subject: Stuart Taylor nose cone and bonnet vs Westfield.
DANMAN
posted on 6/9/12 at 09:59 AM Reply With Quote
Hi guys.
I have a Stuart Taylor that has a pretty knackered nose cone and bonnet. Being in Oz there aren't any Stuart Taylor parts around so I was wondering if anyone knew whether I could use a Westfield nose cone and bonnet instead?
Dan.
Daily Driver - Audi A4 2L Turbo Quattro
Work Horse - Falcon XR8 Ute - Now Supercharged!
Rally Beast - 1972 Ford Escort 2L
Off The Road - Locost 2L Turbo (Z1 Concept)
Track Car - Stuart Taylor Blade
scutter
posted on 6/9/12 at 10:15 AM Reply With Quote
I don't think so, the westfield bonnet and nose have a crease in them that they put in to stop Caterham suing them.
ATB Dan.
twybrow
posted on 6/9/12 at 11:14 AM Reply With Quote
I hav Luego bodywork on my ST - it does mean you need to change scuttle too, as they are higher than the ST bodywork....
mark chandler
posted on 6/9/12 at 12:34 PM Reply With Quote
I cannot see why you could not fit a westfield nose cone (pre litigation) and bend up and ali bonnet.
If a later nose cone as above then with care you could make an ali bonnet to suit and taper the additional creases into the bonnet so lost bu the time you reach the scuttle.
My bonnet was just formed over a bit of plastic drain pipe with the hard creases between a couple of lengths of angle.
Bladerunner
posted on 6/9/12 at 06:56 PM Reply With Quote
Nose Cone
I bought my car from Ian at Stuart Taylor, when I asked him about various bits like windscreen, he said it was all based around a Caterham. So you should find the nose should be about the same size.
Adventure before Dementia
DANMAN
posted on 6/9/12 at 10:13 PM Reply With Quote
Thanks guys.
The Westfields are plentiful over here in Oz (although not where I'm located) so I will see if I can borrow one for a few minutes at the next race meet I go to and get some measurements.
