jeffw
posted on 10/9/12 at 08:46 AM |
Cambelt idler failure
Out on a nice run with the Southern Kit Car Club yesterday (with Son in passenger seat) when the engine stopped at a junction near the A26. An
attempt to re-start had metallic top end noises....so lifted the bonnet to find
You can see the failure of the idler pulley which has allowed the cambelt to jump in the pictures. Without the Supercharger frame I think it would
have been gone completely.
4 hrs for the AA to recover the car allowed a lot of time to reflect. Less than 500 miles since the cambelt was changed when the engine was rebuilt
and the idler pulley has failed....not happy bunny.
I can't imagine the idler is under any more strain than it would be in the orginal vehicle (?) so maybe I've just been unlucky (again).
Likely to be head/pistons/valves at a guess...
Davegtst
posted on 10/9/12 at 08:55 AM |
Was the idler changed with the cambelt? I never fit a cambelt without changing the idlers and tensioners now unless the customer specifically tells
me not to. I had a nasty experience on a focus once that cost me a fortune and a lot of stress to put right.
jeffw
posted on 10/9/12 at 08:59 AM |
I don't know is the easy answer. The whole engine is only 5K old so worse case the idler has that many miles on it although you would expect it
to be less than 500 miles. I'll find out this morning...
jollygreengiant
posted on 10/9/12 at 10:23 AM |
I'm afraid its the old story, you change the cambelt and no matter how hard you try to get it the same, you end up with a different tension.
Plus it was probably being driven with a bit more gusto than it was used to.
ashg
posted on 10/9/12 at 12:53 PM |
oh dear jeff your not having much luck with the car at the moment.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
jeffw
posted on 10/9/12 at 01:02 PM |
Pulleys where changed with the belt (500 miles ago). Looks like one of those things. At least I have ARP studs so it doesn't need new stretch
bolts this time. We will be able to skim the head to increase the CR as well.
Hopefully it will only be the valves as it happened at idle and I'll not need new pistons.
Fatgadget
posted on 10/9/12 at 02:17 PM |
Valves and pistons getting up close and personal when something breaks in the linkage, one can never predict the seriousness of the outcome sadly.
daviep
posted on 10/9/12 at 04:38 PM |
That's a sickener
It may be an optical illusion but the idler doesn't look as if it sitting properly against the block, as if the bolt has come slack?
Davie
Andy S
posted on 10/9/12 at 06:02 PM |
quote: Originally posted by daviep
That's a sickener
Davie
Just what I was thinking
perksy
posted on 10/9/12 at 06:07 PM |
That's a sickener
Davie
Was just thinking that myself
Is the bolt loose ?
RickRick
posted on 10/9/12 at 06:16 PM |
goes with the damage to the outside of the pulley too
ian locostzx9rc2
posted on 10/9/12 at 06:56 PM |
Looks like a bent or misaligned idler pulley bolt/or idler to me!
hicost
posted on 10/9/12 at 07:13 PM |
Pistons
When you pull it apart, can you get away with putting a pocket on the pistons for the valves, that way it will inimise the damage if it happens
again.
Best of luck
James
"I cant do that without accidentally grabbing hold of the work of the divine potter"
jeffw
posted on 10/9/12 at 09:07 PM |
It has forged HC pistons with pockets in them already. Also port/polished head with large valves & high lift cams.
The Idler pulley has failed causing the belt to jump. Just how or why it has failed remains to be seen.
ashg
posted on 10/9/12 at 11:49 PM |
looks like the bolt has come loose to me.
unfortunately jeff it may be a case of the age old saying. "If you want the job done properly do it yourself." failing that have you
thought about getting dick to have a look at it? i don't know of a person that has a bad word to say about him,and he is one of the very few
people that i would allow to touch one of my cars.
jeffw
posted on 11/9/12 at 06:50 AM |
I think you maybe correct
jeffw
posted on 11/9/12 at 05:19 PM |
And today I ran over something on the M25 which has buckled the 19" alloy on the Jag. I had to change the wheel on the side of the motorway for
one of those stupid space savers and then gone on to Birmingham. New wheel and tyre will be required
six mad
posted on 11/9/12 at 06:22 PM |
Oh thats Bad luck, hope you get it sorted soon.
I would suspect as the belt tension has become slack, this has allowed the cambelt to ride on the top of the pulley
causing the belt to become very tight which in turn has bent the idler pulley mounting bolt.
This could have been caused by incorrect tension on the cam belt in the first place.
daviep
posted on 11/9/12 at 08:04 PM |
Wouldn't be my first guess as to probable cause, not sure which pulley you think it would ride on to the top of?
Ever heard of Occam's razor?
Davie
snakebelly
posted on 11/9/12 at 08:14 PM |
Am i seeing things or is there a hairline crack radiating from behind the tensioner bolt at approx 3 o'clock?
six mad
posted on 11/9/12 at 09:13 PM |
Davie
Nah, I use Gillette
Tooth on tooth- cam belt against exhaust cam pulley, The belt is even trying to ride the pulley in the pic.
jeffw
posted on 18/9/12 at 10:39 AM |
Idler had seized/failed and then bent the bolt holding it on :shock:
Damage is 4 exhaust valves and 2 inlet, guides are fine and the pistons have some very minor marks..
ian locostzx9rc2
posted on 18/9/12 at 11:49 AM |
Now you need to why it happened!!!!
Nick DV
posted on 18/9/12 at 12:26 PM |
Davie
I agree with you Davie, it wouldn't be my first thought. Probably nothing more than a manufacturing problem with the pulley.
Yes, I have heard of Occam's Razor - many years ago in 6th form - but more recently from Jodie Foster in the film 'Contact!'
Geoff, bad luck but I hope you get it sorted soon.
Cheers, Nick
"The force will be with you, always!"
jeffw
posted on 18/9/12 at 12:52 PM |
There is going to be a metal idler fitted which should alleviate the issue happening again.
