Author: Subject: Red Top Refresh before install
mcg
posted on 17/9/12 at 04:21 PM Reply With Quote
After many previous threads about installing a V6 vaux unit into my F27, I have backtracked a bit and decided to go for a red top C20XE. The install will be alot easier given it will be able to use much of the cooling system and (hopefully) engine mounts as well as bell housing used on my 20NE 8v install, and there is a good chance I can get it road registered before the spring.
I have found one at a decent price with older dizzy set up which I am picking up on Thursday. I will be transplanting the shortened sump from my 8v and oil pick up.
Are there any other things that you'd recommend I do whilst the engine is out before I install such as clutch and cam belt?
No history on the red top so no way to know if and when cam belt and clutch was done. Is there any way to tell?
sdh2903
posted on 17/9/12 at 04:27 PM Reply With Quote
May as well while it's out? Would be annoying if anything went/wore out after you'd finished the install.
wylliezx9r
posted on 17/9/12 at 04:31 PM Reply With Quote
If it was me I would definately replace the following before installing:
Full clutch assy
Cambelt
Cambelt tensioner
waterpump
Maybe worth getting a compression test done as you have no history of the engine. The last thing you want to do is install it and then find problems. Engines are much easier to work on whilst on the bench.
Just my 2 pennys
HTH Dan
George Best
pmc_3
posted on 17/9/12 at 06:15 PM Reply With Quote
Oil pump wouldn't be a bad shout as the pressure relief valves can stick
perksy
posted on 17/9/12 at 07:03 PM Reply With Quote
Had the pleasure of working on a few of these
Autovaux are good for parts
Replace the cam belt and pulleys, consider going for steel pulleys if your planning on track work
(If not fit a gates branded timing belt kit)
New OE oil pumps have become quit expensive on these, So it might be worth just replacing the oil pressure releif valve with the SBD version or polishing up the standard steel one if already fitted (sticking oil pressure releif valve is a known problem)
Replace the water pump if the history of it is unknown
Check the rear crank seal as this is an XE weak point, replace it if unsure as if it leaks in the car its a pita to do
Modify the cam cover for RWD use if it hasn't already been done, Details on the SBD website
Check the condition of the big end bearings and replace the standard bolts with ARP ones afterwards
You might want to consider carrying out the XE oil gallery modification to the cylinderhead unless your very lucky and yours comes with a Coscast, but it might be better to leave that one for now and seeing how you go
Well worth a good read of the SBD website as there's some really good info on there
Any queries please ask
[Edited on 17/9/12 by perksy]
loggyboy
posted on 17/9/12 at 07:19 PM Reply With Quote
I bought mine on 143k, and put it straight in my first Nova with a new clutch kit, then did about 10-15k and then put it in a 2nd nova, I then did a cambelt, tenstioner and water pump and head gasket.
It then rolling roaded at at 143bhp (at the wheels!)
LOVE THE REDTOP!
Mistral Motorsport
