flibble
posted on 27/9/12 at 05:04 PM |
rolling tubes from sheet, maths fail. Help !
Hi all
My old feeble maths skills have yet again let me down, I've nearly managed to grasp the concept in my head but the more I think about the
problem, the more confused I get, excuse my following ramblings, they may not make sense!
Over the next year or so at work I'm going to have to roll a lot of aluminium sheet into tubes, which can then be stuck together in all manner
of different angles, a bit like slicing a tube at 45deg and welding the the two parts back together to form a 90deg elbow (if that makes sense?!) only
im starting from flat sheets of ally.
The easiest way to do this for me would be if I could print paper templates at work to trace around (absolute accuracy not entirely essential) and
then cut out, roll and put together.. etc..
Would I be right in thinking that an unrolled tube once cut at say 45deg would be a sine wave, with the tubes circumference being the wavelength? how
do I work out the amplitude of the wave for different angles etc?
In short, how do I use the sine function y=Asin(Bx) to achieve my goal? (if it's possible and anyone's still reading!)
KevD
posted on 27/9/12 at 05:15 PM |
Download Tubemitre??
flibble
posted on 27/9/12 at 05:22 PM |
Ahh, shall do, thanks
Although, I'd still really like to know the math behind it or it'll bug me for days ![](/images//smilies/wink.gif)
AdrianH
Have a good read
eBay Item
Adrian
Why do I have to make the tools to finish the job? More time then money.
liam.mccaffrey
posted on 27/9/12 at 05:58 PM |
in your example y=A Sin(Bx) A is indeed the amplitude and B would be the frequency
I'm thinking about the equation you need is somthing along the lines of y= 0.5 * tube diam* tan (angle of mitre cut) * Sin(x*tube
circumference)
I was close but I think me! has got it in one i reckon
[Edited on 27/9/12 by liam.mccaffrey]
Build Blog
Build Photo Album
me!
posted on 27/9/12 at 06:00 PM |
Possibly this, but I was well known for my imaginary maths skills at uni, so it could be bo**ocks. I'm sure someone will let me know!
![](/galpreviews/imaginary maths.jpg) ![Potential maths fail](/gallery/imaginary maths.jpg) Potential maths fail
EDIT: Just realised that doesn't quite work, X limits should be 0 and 2.
[Edited on 27/9/12 by me!]
NigeEss
posted on 27/9/12 at 06:04 PM |
Cheaper on Amazon
flibble
posted on 27/9/12 at 06:28 PM |
Cheers for the help lads
Think I've got it now, will try it out tomorrow, looks more complicated on paper than it probably should do!
MikeR
posted on 27/9/12 at 08:07 PM |
Look up people making racing bikes by hand. Their are some excellent interactive web sites that do what you want.
bi22le
posted on 27/9/12 at 08:13 PM |
I know that you have good answers but i want to add my 2p.
I was under the same thought that is a sine wave with a relationship of angle to the amplitude.
Its not that simple because you need a sharper peak at the top of the wave and flat at the bottom of the wave.
I was battling with exactly the same problem when building my inlet manifold.
Please read my ring story:
TAZZMAXX
posted on 27/9/12 at 08:55 PM |
I know it's not very Locost but it's an example of the book, probably cheaper on ebay, and it will explain everything you need to know on
the subject. It is classed as pattern development, very interesting as well. I've had this and the advanced book for a few years. It's
always useful to know how to do it manually rather than mathematically.
http://www.amazon.co.uk/Geometry-Sheet-Metal-Work/dp/0582009618
posted on 28/9/12 at 12:55 PM |
The shape is a sinusoid. Have a look at this pdf for the equation for the simple
case of a plane intersecting a cylinder, as well as far more complex sections.
