Author: Subject: Rear Camber Adjusters
Markyb13
posted on 1/10/12 at 06:44 AM Reply With Quote
Hi all
Does anyone know where I can get a replacement rear Camber adjuster, i can't find the type MNR use any where.
I know I can get them from MNR but at nearly £50.00 each they seem a bit expensive, wondered if I could get them cheaper anywhere else.
amalyos
posted on 2/10/12 at 06:28 PM Reply With Quote
Are you talking about the Aluminium adjuster? I can't believe MNR want £50 for one of those, a new wishbone isn't that expensive!!
http://stevembuild.blogspot.com
40inches
posted on 2/10/12 at 08:28 PM Reply With Quote
I have seen them on eBay for less than that for a pair in steel, and I believe that Flack Monkey makes them.
http://www.locostbuilders.co.uk/viewthread.php?tid=156335
[Edited on 2-10-12 by 40inches]
Markyb13
posted on 2/10/12 at 08:43 PM Reply With Quote
Camber adjusters
Hi
Yes I am talking about the aluminium adjusters, Chris at MNR quoted £44.00 each plus £5.00 postage.
I have struggled to find any the same online, only ones for the front but hese are too short !!
I'll have a look again on eBay, steel would be better, bit worried about the same thing happening again and stripping some of he treads and ending up with a horizontal wheel !
I'll u2u flack monkey too,
Thanks for the advice
[Edited on 2/10/12 by Markyb13]
loggyboy
posted on 2/10/12 at 09:37 PM Reply With Quote
Are mnr rear ones diffrerent to the usual front ones? L0cost/haynes style front ones that were readily available in alloy and steel versions, but do they suit the MNR rear?
Mistral Motorsport
ashg
posted on 2/10/12 at 09:51 PM Reply With Quote
if you send/bring me the other one or a very accurate drawing i can copy it for you but i will only make it in steel as ali is crap for this sort of thing.
[Edited on 2/10/2012 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Markyb13
posted on 3/10/12 at 12:21 PM Reply With Quote
Hi
Thanks for your reply, i will endever to get the other one off and send you the details or the part, if you could fabricate it that would be great.
Mark
Markyb13
posted on 8/10/12 at 06:02 PM Reply With Quote
Hi all
Thanks to those that replied, I have managed to track down the person hat was selling hem earlier this year on eBay, now ordered and sorted
