Author: Subject: Clutch cylinder pipework Ford V6 - Duratec
karlak
posted on 1/10/12 at 02:33 PM Reply With Quote
Can anyone who has used the Ford V6 (Mondeo i think) clutch cylinder, with their Duratec Bellhousing please let me know how they connected the hydraulics.
The two connectors are different sizes. Do you have the size of the connectors you used ?
Am a bit vague as I don't have the cylinder with me and am answering the query remotely for someone working on my car.
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
redeye
posted on 1/10/12 at 02:46 PM Reply With Quote
There are only two outlets, one is for the bleed nipple which should be fitted to the cylinder and other is then connected to the master cylinder.
As for the fitting sizes im not sure, I got my hose from Raceline, give them a ring and they will be able to tell you the correct size fitting required
karlak
posted on 1/10/12 at 03:31 PM Reply With Quote
Ahh yes,, Raceline.. Thanks, I will give them a shout
DIY Si
posted on 1/10/12 at 09:04 PM Reply With Quote
What ever you do, fit the bleed nipple on the end of a long bit of pipe that you can get to! Much, much easier to bleed that way.
Sun Tzu, The Art of War
