<<  1    2  >>
Author: Subject: Lotus Seven parts
metro6r4
posted on 2/10/12 at 08:16 PM Reply With Quote
Lotus Seven parts
hi im stripping my lotus seven project as i have just bought a global gt and need to thin out my projects as iam ruunning out of room so its goot to go i had about 3/4 of the parts and will start listing them on hear and eventually ebay if no locosters can make use of them i will put more pictures on here and more items as i clear out my sheads if you are intrested in any of it then please call me on 01359233157 or u2u me
I have a set of gas shocks and springs like new with a few marks never fitted to the car but never been down the road don’t have the boxes anymore but they are as good as you will get will upload pics tomorrow and check the spring ratings I paid £247 from rally designs they the ones with the adjustable dampening I am after £150 or very near offer that is £100 of retail price
I have a 4.1 diff still in the axle with drums the diff is in good working order the axle has been painted with hamerite with a good thick coat the diff was stripped cleaned and inspected by escortec when I got it the drums have been sandblasted and painted im after £100 for it
I have a wheel and removable boss for sale never fitted to my car bought it to go on my lotus seven that I was building but I bought a global gt last weekend i am after £50 it’s like new global already has one is 255mm diameter
I have a set of 15 inch 7j rims they are the same as the team dynamics multispoke’s in black alloys they are brand new in the box never been of the box still wrapped except for one to take pictures they are 4 stud with 108 fitment to fit ford Citroen pergueot and some others I will include some wheel spaces as well im after £200i have a set of stainleess wheelnuts for an extra £10
I have a brand new never used just unboxed obp pedal box with twin break cylinders and bias bar it bhas a 25x25mm recess in it to fit straight up to the bulkhead .it has two master cylinders, 2 resevoirs and a pair of braid lines to the resevoirs its for a cable clutch but could easily be adapted to hydraulic clutch the pedals arein a 5.1 ratio it cost me £269 im after £140 or near offer it’s a £129 off retail price
I have a caterham dry sump bellhousing to convert a rover k series to fit a ford type 9 it has a few marks and a small crack that has been repaird but will not affect performance it can be used with an apolo tank that you can buy from caterham to save space im not certain but can be used with a dry sump these are £576 new but I will take £130 or near offer
I have a group a hydraulic hand break with wildwood master cylinder still all bagged up bought it for the seven but never fitted it rally designs want £80 I would take £40 would keep it if the global needed a handbreak
I have a rover k series 4 branch manifold with individual headers with a 4 to 1 collector and a Westfield silencer the headers have just been wrapped with dei heat wrap this week which is not cheap nasty rubbish there’s a whole reel on their which is about £50 worth the silencer has a couple of small bumps in it but nothing major and will not affect performance it is not pristine but is in vgc this setup will give a reasonable increase in performance over the standard this setup would cost around £950 new want £250
I have a set set of front wish bones uprights and calliper’s the brake calliper’s have just been refurbished and anodised in gold by a local firm along with the wishbones and uprights the hubs have had a new bearings and alloy grease caps there from a Haynes locost and possibly some others I have been told the breaks and uprights were from a Cortina but I am uncertain I have a brand new set of pads for the buyer to fit there are a few marks but you probally wont notice when the wheels are fitted and will throw in a steering rack as well I am after £120
I have a radiator that I have been told is from a mk2 escort but I’m uncertain it still has the suppliers name tag on it never fitted £45 ono
[Edited on 2/10/12 by metro6r4]
daniel mason
posted on 2/10/12 at 08:20 PM Reply With Quote
might know someone who could want pedal box. will let him know
hicost
posted on 2/10/12 at 08:28 PM Reply With Quote
Hi
I will take the pedal box please.
James
"I cant do that without accidentally grabbing hold of the work of the divine potter"
hicost
posted on 2/10/12 at 08:33 PM Reply With Quote
parts
Hi
I will take the handbrake and cylinder also.
James
Wheels244
Bloody 'ell - I only went to the toilet and the pedal box sold !
Interested if it falls through.
SteveMX5
posted on 2/10/12 at 08:39 PM Reply With Quote
U2U sent
metro6r4
posted on 2/10/12 at 09:24 PM Reply With Quote
i am in bury st edmunds the pedal box and hand break have been provisionaly sold to hicost with first dibbs on the handbreak going to unijacko67 if the sale to hicost falls through
i will be adding a straight cut type 9 gear box that has only just been built and not used
a rover k series race engine with exige throttle bodies profeesionaly ported custom head uprated mls gasket new caterham ultralight flywheel new ap clutch new caterham starter emerald ecu remote mount oil filter kit with oil cooler, and lightweight cranck pulleythe engine was from an elise having only done 44 thousand it has been profesionally mapped and is producing 220hp
AdrianH
posted on 3/10/12 at 07:01 AM Reply With Quote
U2U sent regards dampers
Adrian
Why do I have to make the tools to finish the job? More time then money.
renrut
posted on 3/10/12 at 08:20 AM Reply With Quote
U2U sent
Why are all the fun things in life expensive!
nib1980
posted on 3/10/12 at 09:05 AM Reply With Quote
where were you when i needed new wishbones and shocks a week ago!
just oreder some new bones to be custom made.....
arrrrgggghhhh
metro6r4
posted on 3/10/12 at 07:37 PM Reply With Quote
here is a picture of the steering wheel and boss
i also have a chasis for sale including some pannels bonnet and scuttle panhard rod and trailiing arms im after £100
Wheels244
posted on 3/10/12 at 08:24 PM Reply With Quote
How much is the steering wheel please ?
metro6r4
posted on 3/10/12 at 08:28 PM Reply With Quote
with a quick release boss £50 plus postage the boss cost me more than that may still have the horn button as well somewere thats not including postage but that wont be much
silky16v
posted on 3/10/12 at 10:46 PM Reply With Quote
Anymore info on the Type 9 gearbox? Is it still available?
metro6r4
posted on 4/10/12 at 05:32 PM Reply With Quote
wishbones calipers hubs and uprights are gone as well as the shocks the gearbox is for sale will get pics and post more info soon
metro6r4
posted on 5/10/12 at 08:24 PM Reply With Quote
i have a bosh 044 fuel pump brand new in the box with fitting kit Probably, the most popular aftermarket fuel pump. Capable of providing 300 LPH free flow and 200 LPH at 5 bar (or 72.5 psi) for up to 685 BHP.
cost me £150 will take £100 ono
hicost
posted on 5/10/12 at 09:55 PM Reply With Quote
Pump
Hi me again I will take it, thanks.
What about the post
Regards
James
metro6r4
posted on 5/10/12 at 10:21 PM Reply With Quote
hi hi cost i have sent you a u2u
hicost
posted on 5/10/12 at 10:35 PM Reply With Quote
Pump
Just paid via PayPal
James
metro6r4
posted on 5/10/12 at 10:56 PM Reply With Quote
fuel pump and wheel have now sold
i will be putting up a fuel lab adjustable fuel presure regulator and a fuel lab 100 micron serviceable fuel filter tomorow
silky16v
posted on 6/10/12 at 07:56 AM Reply With Quote
Hi any further info on the Type 9?
metro6r4
posted on 6/10/12 at 02:17 PM Reply With Quote
silky 16v you have u2u
metro6r4
posted on 6/10/12 at 10:02 PM Reply With Quote
i have a straight cut type 9 gearbox that has just been rebuilt by first motion and hasn't been used since i still have the receipt. it cost me £1650 without the cost of purchase it is fitted with a caerham k series bellhousing at the cost of £300 just had a caterham clutch release bearing. everything on this box has been uprated or renewd it has been fited with a tranx gear kit uprated oversized rollers and bearings it comes with a large collection of coomma gear oil this set up is good for 300hp i will take no less than £1200
metro6r4
posted on 7/10/12 at 01:22 PM Reply With Quote
all orders dispatched
metro6r4
posted on 7/10/12 at 04:46 PM Reply With Quote
dry sump bellhousing now sold will be adding more soon
<<  1    2  >>
