Author: Subject: Buffing tyres??
pewe
posted on 5/10/12 at 03:16 PM Reply With Quote
Buffing tyres??
The previous owner went drifting hence the spare tyres have shouldered quite badly.
Since I intend doing a mixed surface Autosolo soon I reckon I'll use those tyres but they need buffing - any suggestions as to what I should use?
I'm contemplating the angry grinder with a sanding disc or the electric drill.
And before anyone suggests it "No" I don't fancy doing it this way! linky
Thanks in advance.
Cheers, Pewe10
designer
posted on 5/10/12 at 03:33 PM Reply With Quote
Your local 'better' quality tyre suppliers (not kwikfit and such) could have a tread cutter.
adithorp
posted on 5/10/12 at 03:59 PM Reply With Quote
How about the WELDERMAN method then...
http://jpsc.org.uk/forum/
loggyboy
posted on 5/10/12 at 04:14 PM Reply With Quote
Buffing? If theyve been drifted surely buffed?
I thought buffing (or scrubbing) was done by racers to treaded tyres to take off the top surface and reduce the size of the tread blocks to reduce lateral movement.
Mistral Motorsport
maccmike
posted on 5/10/12 at 04:57 PM Reply With Quote
think id rather have the track mileage and let them buff on the go
andrew
posted on 5/10/12 at 05:15 PM Reply With Quote
i use a electric planer doesnt get them hot like a angle grinder, you can put desired camber on very easy
Steve Hignett
posted on 5/10/12 at 09:28 PM Reply With Quote
What's a tread cutter got to do with buffing the tyres???
I'm with Adi on this one, the Welderman method is the way forward (not for buffing the tyres you understand, just cos it's pish funny )
Welderman hating his tyres
