Author: Subject: Not runnning right again
whitestu
posted on 8/10/12 at 07:36 PM Reply With Quote
My car is barely getting used at the moment but it has always started and run perfectly when left before. Last time I was out in it it was only running on 3 cylinders at low revs. I cleaned the carbs which made no difference and then changed the plugs and leads which seemed to sort it out.
However when I moved it today it was running on 3 again. I need to whip out the plugs to see what colour they are but was wondering whether the coil pack would be a likely candidate.
What do you think?
Stu
posted on 8/10/12 at 08:07 PM Reply With Quote
A bit more information might help? What engine etc
whitestu
posted on 8/10/12 at 08:46 PM Reply With Quote
Good point!
Blacktop 2.0 Zetec, megajolt and ZX6R carbs. Been running great for the last 4 years.
Chippy
posted on 9/10/12 at 09:59 AM Reply With Quote
Could be just dampness on the leads, give them a spray with WD40 or similar and see if that does the job. HTH Ray
Fizzer
posted on 9/10/12 at 12:01 PM Reply With Quote
I think the coil fires in pairs doesn't it? if you had lost a winding you would lose 2 (please correct me someone if I am talking p00)
RichardK
posted on 9/10/12 at 01:12 PM Reply With Quote
Carb on that cylinder causing that cylinder to run hot knackering the plug?
Gallery updated 11/01/2011
