maccmike
posted on 14/10/12 at 05:33 PM |
Clutch Master
Hi, Im playing with the idea of using a motorbike rear foot brake master cyl as a clutch master.
Any input welcome.
alfiebeard
posted on 14/10/12 at 09:39 PM |
Hmm........ might not have the capacity to open a clutch fully, my Viento uses a .75 bore master cylinder you can see it in my profile.
Alfie
Old bloke on a mission with 320BHP of help
Rod Ends
posted on 14/10/12 at 11:12 PM |
It's what DAX did on their ZZR1100-powered rush.
maccmike
posted on 15/10/12 at 07:26 AM |
cheers chaps
daviep
posted on 15/10/12 at 07:31 AM |
That's what I used, only because it was free with my donor ZZR1100
adithorp
posted on 15/10/12 at 07:39 AM |
Due to the small bore, using a bike rear brake master should give a nice clutch pedal feel (but light) to a bike clutch. Seen it recommended sevaral
times. As long as it gives enough stroke at the slave you should be fine. The mounting would be the only issue.
http://jpsc.org.uk/forum/
maccmike
posted on 15/10/12 at 01:18 PM |
thanks all, I will play about in the near future and let you know how I got on
alfiebeard
posted on 15/10/12 at 01:41 PM |
Hi as adithorp said the smaller the bore of the cylinder the easier it is to press,
sorry I did'nt realise that you were using a bike engine in your car, in that case the throw of the clutch would be less so a bike master
cylinder should be ok.
Alfie
