Author: Subject: Brakes
Delinquent
posted on 17/10/12 at 11:49 AM Reply With Quote
Brakes
Afternoon all.
Not been on here for an age after my project plans collapsed due to redundancy, but I've managed to find a little project (beach buggy) to keep me sane again
Now... While I'm very happy with engineering things in general, one thing I'm never too sure on is mix and match modifications. What I need to do really is ditch the twin circuit beetle master cylinder and replace it with two single master cylinders and a balance bar.
So... other than diameter and travel of the piston in the VW unit, is there anything else I need to consider? I'd like to use land rover master cylinders as they're £10 LOL
coyoteboy
posted on 17/10/12 at 12:00 PM Reply With Quote
Only max pressure, which will be similar in all car systems I suspect (but can't guarantee). Assuming the same diam and travel you'll be matching output characteristics.
Delinquent
posted on 17/10/12 at 07:56 PM Reply With Quote
Cheers for the confirmation coyoteboy, I've found landrover ones are the same bore diameter, give or take 0.5mm dependant on model, just got to find travel now!
