Author: Subject: Formula Help with excel, late night can't think :o(
Mr Whippy
posted on 25/10/12 at 10:05 AM Reply With Quote
Hi bad thing to sort out just now, I don't feel well
Spent about an hour on this and so fed up, not helped by noisy folk strimming grass outside the office wtf it's nearly november!
All i'm trying to do is get the cell value to be true and false if the date falls between the week above so the conditional format changes the colour. Tried many versions of the formula and none work correctly
There's some free on the web but IT have blocked any uploads.
The end date is just the start date + the duration
Can anyone help, please
[Edited on 25/10/12 by Mr Whippy]
MRLuke
posted on 25/10/12 at 10:17 AM Reply With Quote
Give me a sec and ill have a look for you
Mr Whippy
posted on 25/10/12 at 10:22 AM Reply With Quote
thanks, still not getting it working aaaahhhh!
Slimy38
posted on 25/10/12 at 10:30 AM Reply With Quote
Your formula is wrong isn't it? In English, yours is;
If the start date is greater than the test date AND test date is less than end date
Shouldn't it be;
If test date is greater than start date and test date is less than end date
or;
=IF(AND(N$2>=$G4, N$2<=$H4),TRUE,FALSE)
MRLuke
posted on 25/10/12 at 10:32 AM Reply With Quote
This appears to work:
=IF($G4>N$2,FALSE,IF($H4>N$2,TRUE,FALSE))
I think it can probably be simplified. As above lol, both work the same.
[Edited on 25/10/12 by MRLuke]
rodgling
You've got IF(condition, true, false)... lose the IF, it does nothing. Just have AND(N$2>=$G4, N$2<=$H4) (or whatever it needs to be).
Mr Whippy
posted on 25/10/12 at 10:35 AM Reply With Quote
yeah it works! Well done what a difference a fresh mind makes or one less hung over
Thank you very much that was a big help
