Author: Subject: C20XE – A few questions
mcg
posted on 5/11/12 at 02:45 PM Reply With Quote
Just prepping the redtop to go in my F27 and need some pointers:
1. These 2 sockets (pic A) appear to be for the 2 plugs shown attached (pic B), but they were not plugged in when I got it, so not 100% sure? I am looking at cooling system set up for the redtop – am I supposed to remove this sensor attached to the bottom of the inlet manifold anyway or does the ECU need it? If so, do I have the right plugs.
[/img]
2. What are these plugs / relay for and should i do anything with them?
[/img]
[/img]
3. Just need to confirm that the red wire ‘a’ should be connected to the terminal ‘a’ on the coil. Again was not connected when I got the engine, but the nut was loose which implies that’s where it came from.
[/img]
I have heard some bits you can cut off, but I dont understand what the ECU needs to function or what doesnt. I know it should be pretty straight forward, but any help or pointers would be really appreciated.
Thanks in advance.
Matt
loggyboy
posted on 5/11/12 at 02:56 PM Reply With Quote
OK lets see,
first is the idle control valve (stepper motor) (round metal cylinder, bosch). Its connected to the base of the inlet and will be needed if using standard injection/ecu.
I dont recognise the other connector, not sure what sensors are under that area of the car.
If the relay has a few different red/blue striped cables it will be the fuel relay.
I think the large square connector its the connector to main loom, you should only need one cable from this, a black one that will be the accesory live (needs to remain live when cranking)
cable 4 looks like the main power supply, if its red it is and goes to the battery +.
5 is the ron plug, this should be set to which ever fuel you use
[Edited on 5-11-12 by loggyboy]
Mistral Motorsport
mcg
posted on 5/11/12 at 03:24 PM Reply With Quote
Great start -thanks for that loggyboyl. Its a good point I forgot to mention: I am running standard injection ECU.
Originally posted by loggyboy
OK lets see,
loggyboy
posted on 5/11/12 at 03:31 PM Reply With Quote
My knowledge is a little limted as it seems you have the earlier 2.5 motronic dizzy engine, mine was the 2.8 dispac which had some variations.
Good place to ask is migweb on PNGclub, lots of expeience with all GM lumps on those.
Mistral Motorsport
tomgregory2000
posted on 5/11/12 at 03:33 PM Reply With Quote
The sensor on the side of the block is Iirc a knock sensor
loggyboy
posted on 5/11/12 at 03:51 PM Reply With Quote
That would make sence as I know thats something the later versions (like I had) didnt have.
Mistral Motorsport
mcg
posted on 5/11/12 at 04:12 PM Reply With Quote
Ok - so probably needed then - just need to confirm which plug goes onto it...
Ben_Copeland
posted on 5/11/12 at 10:58 PM Reply With Quote
Yep idle control and knock sensor
Ben
Locost Map on Google Maps
Enter Your Details Here
