Author: Subject: Gulp! 4C8 R1 Wiring
TimC
posted on 5/11/12 at 08:45 PM Reply With Quote
Gulp! 4C8 R1 Wiring
Ugh... laid-out my wiring loom for the first time this evening. Oh boy, it's a big one. I may be some time (months.)
Any tips on the best way to work?
MK9R
posted on 5/11/12 at 09:08 PM Reply With Quote
Label all the wires and mark them off on the diagram, makesure you know what every wire does, then start ripping out the lighting wires, 1 by 1. cross the wires off the loom diagram as you do it. you will start to find common earths you can remove as you go along.
i hate wiring, and poo at it, but doing it slowly and i can just manage it
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
ko_racer
posted on 6/11/12 at 12:11 AM Reply With Quote
It's not too hard. I've posted up various simplified diagrams of 5pw and 5vy looms. The basics are all the same just with a few more sensors on the newer models really. The bypasses and relay circuits all pretty much work the same.
TimC
posted on 6/11/12 at 07:55 AM Reply With Quote
So, once the main plugs are identified, is it sensible to then remove all of the secondary sheath/wrap?
jelly head
posted on 6/11/12 at 08:11 AM Reply With Quote
You'll be alright, i have exactly the same engine and once everything was identified and labeled it was pretty straighforward.
I just stripped the wrap off as i needed to and once i'd chased any unwanted wires back i just replaced it to keep everything neat.
adithorp
posted on 6/11/12 at 09:08 AM Reply With Quote
Thats what I did with my 5vy, but only from the main loom.
Best thing I did was get the wiring diagram printed in A3. That made it a lot easier to follow. A2 would have been even better but a didn't think the image resolution would have been any good.
I removed all the lighting wires then got the engine running on the rest. Then altered the engine loom to suit. I re-started the engine after a few alterations to check I hadn't fouled up... alter, check , repeat. That way you know the cock-up is in the last couple of bits you've done if it won't start.
I used glued, heat shrink connectors for the extended wires. They're secure and water tight
http://jpsc.org.uk/forum/
-matt
posted on 17/11/12 at 10:48 AM Reply With Quote
Ey i remember this!!
