Author: Subject: Mounting oil cooler sideways
tegwin
posted on 10/11/12 at 06:24 PM Reply With Quote
I have a standard mocal type oil cooler with the connections on the top.
Can I turn the entire cooler through 90 degrees so the inlet/outlet are on the side? Obviously feed the hot oil into the top and take cool oil out the bottom?
www.verticalhorizonsmedia.tv
designer
posted on 10/11/12 at 06:36 PM Reply With Quote
You can, as long as you can bleed it of air.
MK9R
posted on 10/11/12 at 06:38 PM Reply With Quote
Ran mine like that for 2 years in the race car, no probs
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
tomgregory2000
posted on 10/11/12 at 07:12 PM Reply With Quote
Will be fine, don't worry about trying to bleed air etc it will be fine
The factory fitted one on my defender is up the side of the radiator
Davey D
posted on 10/11/12 at 07:15 PM Reply With Quote
Im sure I've seen a fitting guide that says fitting it at 90deg gives optimal cooling
Fatgadget
posted on 10/11/12 at 07:24 PM Reply With Quote
I've seen oil coolers mounted sideways,upright,flat.... in fact every which way imaginable.Ive also seen them blanked off with gaffer tape!
posted on 10/11/12 at 07:27 PM Reply With Quote
Unlike a water rad It will have to be in at the bottom and out at the top to let the air out .
tegwin
posted on 10/11/12 at 08:29 PM Reply With Quote
Excellent news
Do Mocal use a standard thread on the male connectors to the cooler? I need to somehow step it down to 10mm copper pipe (cooling for a jet engine)
Slimy38
posted on 10/11/12 at 08:30 PM Reply With Quote
But surely unlike a water radiator you're not overly bothered about a bit of air? Water systems are under pressure (and get a bit funny with air in the system), wet sump oil systems aren't?
posted on 10/11/12 at 09:50 PM Reply With Quote
70psi is a bit more than you get in cooling system.
posted on 10/11/12 at 09:51 PM Reply With Quote
A air in the cooling system might cause overheating if it's sufficient to airlock it, but it won't starve your main and big end bearings of oil at an inappropriate moment...
