<<  1    2  >>
Author: Subject: Which CAD Software
Minicooper
posted on 13/11/12 at 04:02 PM Reply With Quote
Which CAD Software
Hello all,
What is the market leader CAD PC for windows package these days, hopefully available for a reasonable price
twybrow
posted on 13/11/12 at 04:07 PM Reply With Quote
How much do you want to spend and what do you want to use it for?
Industry standards are really:
- ProEngineer
- Catia
- Solidworks
They all have pros and cons depending upon what you need to use them for. Catia would be the choice for most people I suspect (it is widely used in autotomotive and aerospace industries. ProE is also a greta package, although maybe not as inutitive to use. Solidworks is more aimed at the smaller business/lighter user and in my experience.
Minicooper
posted on 13/11/12 at 04:14 PM Reply With Quote
Primarily used for 2D dxf drawings for laser/waterjet cutting, also some light 3d work, to show the finished flat plates folded into there final shape. In CAD terms simple stuff and potential budget £250~£300
SeaBass
posted on 13/11/12 at 04:16 PM Reply With Quote
I would agree the main players for engineering and product lifecycle are;
Siemens NX
Dassault Catia
Dassault Solidworks
PTC Creo
ProEngineer is now known as Creo. It's very powerful with great support - I use it daily albeit in an academic setting.
Just seen your reply! A commercial copy of any of those will be way out of budget.
[Edited on 13/11/12 by SeaBass]
FASTdan
posted on 13/11/12 at 04:19 PM Reply With Quote
Inventor as a competitor to SW. Still miles out of that budget.
There's an inventor lite apparently (though resellers never mention it because it doesnt make any money) but even that is circa £1100 per year.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
Minicooper
posted on 13/11/12 at 04:28 PM Reply With Quote
Maybe up to £500 perhaps
loggyboy
posted on 13/11/12 at 04:30 PM Reply With Quote
Autocad is the market leader for 2d CAD.
Mistral Motorsport
Ivan
posted on 13/11/12 at 05:02 PM Reply With Quote
The above are all excellent products but gor around 100 something like Turbocad might work for you.
Not sure how good it is for folded plates however - you would have to look into that aspect.
I use it occasional y and find it works reasonably well given my lack of experience and it's pretty good at importing or exporting most drawing formats - especially the pro version.
You can normally download an older version for trial purposes.
chris-g
posted on 13/11/12 at 05:09 PM Reply With Quote
Intellicad is a good competitively priced alternative to AutoCAD. It usually forms the basis for other software developers to customise. It uses virtually the same commands and reads and writes dwg files. At one time there used to be a free version.
http://www.intellicad.org/
I have used software from these developers and been happy with it:
http://www.progesoft.com/
http://www.autodsys.com/
mcerd1
posted on 13/11/12 at 05:10 PM Reply With Quote
even autocad LT is still not cheap (~£1200)
free trial's on the autodesk site
rhino is cheaper (€995), but its more for making curvy 3D models (its definatly not a drafting package) - but it does have a free trial to download, its easy to learn and its compatable with most things (especially dxf/dwg)
D Beddows
posted on 13/11/12 at 05:11 PM Reply With Quote
If it's just 2D CAD you want then Draftsight - better in my opinion now than standard AutoCad and completely free!
loggyboy
posted on 13/11/12 at 05:16 PM Reply With Quote
Keep an eye on ebay, full packages of Autocad finish within your budget, especially the LT version.
Mistral Motorsport
FuryRebuild
posted on 13/11/12 at 07:04 PM Reply With Quote
I use alibre design. Full monty and it may suit your budget. You can upgrade it in pieces when you need to.
www.furyrebuild.co.uk
SeaBass
posted on 13/11/12 at 07:40 PM Reply With Quote
aka A dying market in the parametric 3D future...
andrewspencer2004
posted on 13/11/12 at 09:31 PM Reply With Quote
for 2D CAD, Draftsight is fantastic and FREE to download, very well supported and does everything AutoCAD does for nothing!
As for 3D CAD, depending on what you want to do with the models once made, have you looked at PowerSHAPE-e from Delcam? its VERY well respected 3D software, the -e version is again FREE and it will import almost any file type you can imagine and allow you to work on solids, surfaces and trianges, the only downside is that if you want to export a file from it you have to pay a fee, but if its just a case of wanting to "see" an assembled part in 3D this could be ideal. There is also alot of free training videos available and a support forum.
If your not too worried about the legality of the software, just find a site and download a copy of Solidworks as this will do both 2D and 3D with ease and the training resources on-line are unbelievable.
bi22le
posted on 13/11/12 at 09:45 PM Reply With Quote
Another big thumbs up for draftsight.
Free and able. its has tricks that only the latest versions of autocad have and i can do 3D drawings in DS.
Its free.
For 3D rendering without to much detail try sketchup from Google.
Also free to to use..
[Edited on 13/11/12 by bi22le]
Please read my ring story:
andrewspencer2004
posted on 13/11/12 at 09:50 PM Reply With Quote
Link to the Powershape-e download page:
http://www.delcam.co.uk/software-downloads/index.asp
Link to the draftsight download page:
http://www.3ds.com/products/draftsight/download-draftsight/
Matt_C
posted on 13/11/12 at 10:16 PM Reply With Quote
Trained using ProEngineer at uni, very powerful but after using Solidworks for the last 2 years would not go back given the choice. Far easier to work with and you dont spend anywhere near as much time pulling your hair. Solidwork is a much much friendlier system to work with, also possible to save ProEngineer parts using Solidworks, not sure from memory if the same is true the other way around.
Both can do all your 2D and 3D work. Both will import and export dxfs which I assume is what you will be mainly using if most of your work is based on cutting files for waterjet or laser cutting machines.
PSpirine
posted on 13/11/12 at 10:38 PM Reply With Quote
I use solidworks because it's very user-friendly and intuitive. I am not such a power user that any of its functional hold-backs affect me.
At work (automotive OEM) we use Catia, and I've had brief experience of ProE but Solidworks is still by far the easiest to get to grips with for relatively simple 2D and 3D drawing for me (I only use it for kit car bits!)
*ETA: Helps to get an academic license I am technically a student still as I'm doing a professional qualification, but ask around your local college/university - we used to get about 50 copies sent to our university for the Formula Student team, I just ask for one every year or so from the current team (they're 12 month licenses, although it doesn't stop working after that as far as I can tell). All projects are marked as educational/academic so probably not ideal if you're planning on drawing commercially for clients
[Edited on 13/11/12 by PSpirine]
phelpsa
posted on 13/11/12 at 11:26 PM Reply With Quote
In my experience, the more capable the package the less intuitive it is.
Although NX and Catia are very powerful tools and brilliant for modelling complex structures and assemblies, they make a lot of simple modelling a lot more complicated than need be.
If you only need simple 2d shapes then go with the simplest and cheapest system that can provide it.
loggyboy
posted on 14/11/12 at 08:41 AM Reply With Quote
(Not from Google anymore, sold to Trimble now, still free ATM though!)
Mistral Motorsport
eddie99
posted on 14/11/12 at 10:14 AM Reply With Quote
As above, shop around, personally go for something like solidworks if you can, very user friendly.... See if you can get hold of a student copy for your own use
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
Matt_C
posted on 14/11/12 at 11:28 AM Reply With Quote
If you don't mind how legit the software is, you can usually get hold trial versions or install the full version without a valid serial or registration code. Plenty of cracks and keygens for then using it as the full version.
As a student me and my mates had the full the Adobe suite, ProEngineer, Solidworks and AutoCAD installed.
Minicooper
posted on 14/11/12 at 12:34 PM Reply With Quote
Thanks everyone,
A few things to think about there, I will investigate
Dualist
posted on 14/11/12 at 06:35 PM Reply With Quote
Problem is that when you originally buy something like Solidworks or Autocad you are only buying the license NOT the software, the software does not belong to you. Found this out the hard way, Ebay pulled my auction for a genuine Solidworks disc so I contacted Dassault and they told me what I have stated above, I don't own the disc even though in my eyes thats the only bit I wanted and paid for originally
Rotary build coming soon...
Originally posted by RichardK
I recently discovered that pigs can p i s s sideways when being transported
<<  1    2  >>
