Author: Subject: Howto: Cheap LED Flasher Relay.
bodger
posted on 24/11/12 at 01:01 PM Reply With Quote
Apologies if this is old news but I managed to convert one of vauxhall relay corsa vectra astra gm 90 055 543 or 54 201 005 . ( I got mine for £1.45 + p.p. - £6.50 seems a bit steep, search around - any relay with a U243B chip inside should work). However it doesn't work with the standard Sierra hazard switch wiring UNTIL you remove the bulb from the column mounted hazard switch. Then it works perfectly. - Not bad for < £4 & 5 mins work.
[Edited on 24/11/12 by bodger]
posted on 24/11/12 at 01:53 PM Reply With Quote
Unless you have a tell tale warning it will not pass MOT or IVA
piddy
posted on 24/11/12 at 02:00 PM Reply With Quote
Would fitting a Led bulb in place of the standard sierra hazard bulb solve both problems?
blakep82
posted on 24/11/12 at 02:06 PM Reply With Quote
Electronic LED Blinker Flasher Relay Fix 3 Pin 12V NEW
<£3 and no work? staright fit, and will work with the tell tale.
have to admit to being a bit confused
________________________
bodger
posted on 24/11/12 at 02:15 PM Reply With Quote
Tried one of those but it didn't work with the Sierra circuit. Tell tale is provided by the left & right green lights flashing on the bike clocks.
piddy
posted on 24/11/12 at 02:54 PM Reply With Quote
I've had two Led flasher relays now the first was a direct replacement for the sierra ones ( lasted five years) the second one had the pins the opposite way around so I had to remove two of the wires out of the relay base and relocate them.
Ben_Copeland
posted on 24/11/12 at 04:41 PM Reply With Quote
Same here, cheap ebay one. Everything works as it should
Ben
Locost Map on Google Maps
Enter Your Details Here
jossey
posted on 25/11/12 at 09:53 AM Reply With Quote
Would it work with an led bulb in the tell tale switch...
David Johnson
L5W
posted on 25/11/12 at 10:41 AM Reply With Quote
Yep, I got an LED tell tale working on my build by adding an earth wire to one of the bulbs terminals and bypassing part of the switch.
a better description and photos in my blog here
cheers
Lee
http://l5w-mk-indy-zetec.blogspot.com/
Darek32
posted on 15/4/14 at 10:46 AM Reply With Quote
Old post but I have some wiring manual that will help when changing on LED
with 2 pin type Led flasher relay
google source
