DANMAN
posted on 25/11/12 at 07:13 PM |
BEC Light weight diff options?
Hi guys.
I currently have an Escort 3.54 diff in my BEC and would like to ditch it for a lighter one. I'm not sure exactly what the Escort diff weighs
but it seems way too heavy for a BEC. What other options are there without a huge amount of stuffing about to change it over?
Daily Driver - Audi A4 2L Turbo Quattro
Work Horse - Falcon XR8 Ute - Now Supercharged!
Rally Beast - 1972 Ford Escort 2L
Off The Road - Locost 2L Turbo (Z1 Concept)
Track Car - Stuart Taylor Blade
daniel mason
posted on 25/11/12 at 07:27 PM |
id imagine an escort diff in a live axle setup is about as light as you will get.
irs cars with 7" or 7.5" ford diffs are way heavier.
generally the problem is ratios on the live axle not been long enough!
mark chandler
posted on 25/11/12 at 07:30 PM |
Unless you go IRS or Dedion which are both a lot of faffing about you are a bit stuck.
All you can do is pop down the breakers and have a scavenge but light cars with RWD as donors must be a bit thin on the ground these days,
minitici
posted on 25/11/12 at 07:36 PM |
You being located in Australia I would have thought that you would consider an Escort axle as lightweight compared to the usual Aussie
V8's...
I suppose you could use something like a Suzuk 1.3i van rear axle but the gear ratio may not be optimal for a BEC.
I suspect that you are unlikely to find a Reliant Robin rear axle in Australia.
daniel mason
posted on 25/11/12 at 08:14 PM |
alfa romeo did a live axle lsd but i would imagine they are heavier than the ford item. and unsure of ratios.
DANMAN
posted on 26/11/12 at 06:25 AM |
Thanks for the help guys. I might save my pennies and go for a Winters unit at some stage.
TimC
posted on 26/11/12 at 12:14 PM |
What about an aluminium diff housing?
DANMAN
posted on 26/11/12 at 11:03 PM |
That was another option I'd been considering. Have yet to find one at a decent price though.
