Author: Subject: indicator cancel cam
Rodeo
posted on 1/12/12 at 07:19 PM Reply With Quote
Hi All
I did ask this within another set of posts,but it may have not been seen,so thought Id start a new thread.I have just bought a Sierra column ,but it has the indicator cancel cam missing. I dont actually need it to cancel the indicators,but only to use as a spacer between the s/wheel and top bearing of the column.Can anyone tell me the depth of the 'tube' ,ie the length? So I can make one from nylon.Im guessing its around 25mm,but need to be sure. Many thanks.
Regards
big_wasa
posted on 1/12/12 at 08:15 PM Reply With Quote
Just the spacer
19mm Id
24mm Od
20mm long
Then You have the cam on the out side of that and a prong on the bottom that locates in the steering wheel boss.
Hope that helps
Rodeo
posted on 2/12/12 at 08:06 AM Reply With Quote
Thats fantastic ,thank you very much.
Rod
