Author: Subject: fuel cap IVA proof???
AndyW
posted on 3/12/12 at 01:51 PM Reply With Quote
Hi guys
Any one any experience of this fuel cap RMD link
As with most things now that Im near the end of the build I want to keep costs down and save for the test.
Would this cap be ok?? I mean its easy enough to make a teather just wondered about the external projections and other considerations
A
Matt_C
posted on 3/12/12 at 01:58 PM Reply With Quote
No at the stage of IVA yet myself but I got a similar filler from car builder solutions which says IVA ok, but that is all I have to go on. The link below seems to be yours which also says IVA ok.
http://www.cbsonline.co.uk/product/Budget_94mm_Locking_Aero_Fuel_Cap_Assembly_Satin_Aluminium_AERO694
renetom
posted on 3/12/12 at 02:46 PM Reply With Quote
cap
Hi
That fine for IVA, BUT , & there's always one.
You will need an unleaded insert for it & make sure its tethered.
If you have not done it yet, don't put it in the back panel but on the top.
You'l save yourself a lot of agro at the pumps.
Good luck
René
Charlie_Zetec
posted on 3/12/12 at 03:30 PM Reply With Quote
Why put it on the top and not the back panel? I think it looks smarter on the rear, and then you don't run the risk of spiling petrol onto the top panel and possibly into the cockpit....
And is the unleaded insert compulsory for IVA?
adithorp
posted on 3/12/12 at 03:31 PM Reply With Quote
Originally posted by renetom
Hi
Good luck
René
Is the unleaded insert still required? I thought it wasn't in the IVA anymore.
As said, teather it. It's open to interretation in the manual so just doit to be on the safe side... and you'll never leave it behind at the pumps.
http://jpsc.org.uk/forum/
renetom
posted on 3/12/12 at 04:33 PM Reply With Quote
Cap
Hi
Pretty sure it still needs to be tethered.
As for the insert , we had to have it in Dec 2011 , he looked for it!
With regards to filler positioning , the reason I said top was that my
son had a Westfield with the cap at the back & was always
complaining about filling it up , stop start, stop start.
If your not sure about anything regarding IVA
Get in touch via email : approvals@vosa.gov.uk
They are very helpful.
We pestered the life out of them & they always came back with
a polite reply.
René
Davegtst
posted on 3/12/12 at 04:55 PM Reply With Quote
It looks exactly the same as my one but mine is black. You will need a teather but thats easy to do. Mine passed ok without the unleaded restricter a few months ago but these testers seem to be very inconsistant.
rdodger
posted on 3/12/12 at 06:29 PM Reply With Quote
I got one of these
Not exactly Locost but has everything you need. Mine is black
40inches
posted on 3/12/12 at 06:35 PM Reply With Quote
The insert was deleted from the IVA test.
big_wasa
posted on 3/12/12 at 07:00 PM Reply With Quote
Yep I have what looks like the same filler and there all made by Newton.
oh yeh water rail is in the post.
On a budget, maybe
eBay Item
[Edited on 3/12/12 by big_wasa]
Acc8braman
posted on 3/12/12 at 07:05 PM Reply With Quote
Hmm, not sure about tethering, the cap must either be tethered to the vehicle or be of a lockable type where the key can only be removed when the cap is locked or an automatically opening and closing, non-removable fuel filler cap
adithorp
posted on 3/12/12 at 07:54 PM Reply With Quote
On those caps they can be turned to the closed position and the key removed without it being fitted to the filler neck. As a result it needs to be tethered.
Acc8braman
posted on 3/12/12 at 08:02 PM Reply With Quote
But you wont be able to put it back in the the filler neck
stevegough
posted on 3/12/12 at 09:11 PM Reply With Quote
You don't need the cap tethered for IVA if the key stays in when the cap is removed (regardless of whether you can remove the key by locking it).
You no longer need to have an unleaded restrictor.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
umgrybab
posted on 3/12/12 at 09:35 PM Reply With Quote
I think they have removed the unleaded fuel restrictor from the IVA, I couldn't find it from the October 2012 one. It used to say you needed one if your vehicle was unleaded and newer than 1990 or something to that effect.
iank
posted on 3/12/12 at 09:54 PM Reply With Quote
They did, based on not being able to buy leaded petrol (from normal fuel stations) for over 10 years, IIRC it was finally banned in 2000(ish) but most stations had stopped selling it well before that.
Might still be worth having if you're the kind of person who might put diesel in absent mindedly
Anonymous
micksalt
posted on 6/4/16 at 10:09 AM Reply With Quote
Cheers guys, you've just saved me £21.60 with this thread.
Mick
