Author: Subject: WTD: Used drill bits
jonabonospen
posted on 4/12/12 at 11:14 PM Reply With Quote
Just about to start my kit and people have mentioned using used drill bits for the fibreglass as sharp ones will just crack and chip the fibreglass.
So has anyone got any used drill bits that would be suitable and which they want out of the way?
MAC#1 ZX10R WORX BUILD BLOG: http://mac1-zx10r-worx-build-blog.tumblr.com/
MY PERSONAL BLOG: http://jonabonospen.tumblr.com/
twybrow
posted on 4/12/12 at 11:17 PM Reply With Quote
Just put masking tape over the point you want to drill and drill from the gelcoat side of the laminate... That will stop it chipping.
blakep82
posted on 5/12/12 at 12:41 AM Reply With Quote
drill all the rivet holes for the panels on the chassis, then you will have a used drill bit
________________________
designer
posted on 5/12/12 at 08:28 AM Reply With Quote
Can't argue with the two above.
posted on 5/12/12 at 09:23 AM Reply With Quote
Spot on
matt_gsxr
posted on 5/12/12 at 10:22 AM Reply With Quote
run them backwards
Confused but excited.
posted on 5/12/12 at 07:48 PM Reply With Quote
Once you have drilled a few holes in fibreglass, you won't have a sharp bit anyway.
Always use masking tape as previously advised.
posted on 5/12/12 at 08:21 PM Reply With Quote
If you have a bench grinder, you can 'back off' the cutting edge of the drill bit to make it suitable for drilling fibreglass without grabbing. Then when you've finished using it for fibreglass, use the bench grinder to put the cutting edge back.
Phil
posted on 5/12/12 at 11:55 PM Reply With Quote
Phil
Drill sharpening is not a skill I've mastered despite many attempts
My Dad on the other hand seems able to do it one handed with his eyes shut - very useful, but at the same time quite annoying
blakep82
posted on 6/12/12 at 02:00 AM Reply With Quote
Phil
i'm the same, i tried once, erm... didn't go well lol. cocked the drill bit up, so i guess i might as well try again...
[Edited on 6/12/12 by blakep82]
bigandy
posted on 6/12/12 at 10:48 AM Reply With Quote
I've got about 100 off 9/16" drill bits that are new you can have for a few beer tokens, if they are suitable size?
Dammit! Too many decisions....
