<<  1    2  >>
Author: Subject: reducing IED casualties - i may have a solution
bi22le
posted on 5/12/12 at 09:08 AM Reply With Quote
Being a design engineer and loving all things in this area i was thinking a few months ago about IEDs in war zones.
I have not beem to war, or know anyone, but have watch our war and various other footage.
I think i have a cheap, fast and simple way of creating safe routes and detiring the use of IED.
How and what should i do about it?
I dont want to develop it any further. I think its a simple process.
Please read my ring story:
johnemms
posted on 5/12/12 at 09:12 AM Reply With Quote
What is it
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
renetom
posted on 5/12/12 at 09:18 AM Reply With Quote
Get out of there
posted on 5/12/12 at 09:22 AM Reply With Quote
It depends what you want to achieve I guess.
If all you want to do is share your idea for the good of those in combat then I'd suggest finding companies that work in this sector and approaching them with a prepared set of plans.
If you want commercial/financial gain from it then you'd do well to think about registering a design, prior art, patent etc to protect your idea before you share it with anyone.
What about sharing it on here and drawing on the broad range of skills/experience to test the theory a bit?
bi22le
posted on 5/12/12 at 09:34 AM Reply With Quote
Not really profit as i see that a little morbid. Recognision would be the best i can hope for.
Ill see what the feedback is on here by the end of the day. I may just post the idea up on here, let you lot tear it apart!
Although i think its a solid solution.
designer
posted on 5/12/12 at 10:17 AM Reply With Quote
Contact the army, who else?
AndyW
If I were you, I would not post it on here. Although you want recognition, there is ALWAYS someone out there who wants the financial gain and will happily steal your idea, market it, patent it and claim it their own and the financial gain that comes with it.
Nice to see that someone has an idea and their first thought is the safety of others before their own need for money. Dont see much of that nowadays, My hat off to you!!
balidey
posted on 5/12/12 at 11:06 AM Reply With Quote
Mine clearing is not a new technology.
I guarantee that your idea, or something similar will have been thought of before and tried.
Two things I will add.
The forces in an explosion are absolutely massive. Your idea may well 'work' to detonate the IED, but that may be all. A little petrol garden rotovator would do the job. But why are they not used? Because of whats needed behind it.
An explosive device can easily lift several tons several feet very quickly.
Second thing, the best way to clear a minefield or IED is to use a #ahem# volunteer.
Either to clear the item or to be used as colatoral damage. Perhaps a job for those on death row?
EDIT: If its radio controlled cars, then I had that idea years ago.
[Edited on 5/12/12 by balidey]
Dutch bears have terrible skin due to their clogged paws
tegwin
posted on 5/12/12 at 11:39 AM Reply With Quote
THIS... is what stifles creativity... don't ever assume this! I have just put a product into the market place (all be it a very small market) which had never been considered before!
www.verticalhorizonsmedia.tv
snapper
posted on 5/12/12 at 12:30 PM Reply With Quote
Design it
Patent it
Promote it
I eat to survive
I drink to forget
bi22le
posted on 5/12/12 at 12:34 PM Reply With Quote
Not even close. Its not about exploding them or so much as detecting them its thinking out side of the box so to speak.
I have seen no evidence as to why my idea will not work or that It has been tried.
James
posted on 5/12/12 at 12:41 PM Reply With Quote
If it's hovercraft then it worked in Die Another Day!
James
Jon Ison
posted on 5/12/12 at 12:42 PM Reply With Quote
Go for it, whats the worst that can happen ? It don't work, whats the best that can happen ? Lives may be saved.
omega 24 v6
posted on 5/12/12 at 12:47 PM Reply With Quote
Go for it.
BUT as others have said don't tell us ( or anyone else for that matter ) about it till its up and running. To many intelectual property theives out there.
The very best of luck to you, especially if it saves our guys in the war zones.
adithorp
posted on 5/12/12 at 01:22 PM Reply With Quote
I'd suspect that Baliday is right... but you never know.
There's not a lot of "new ideas" out there but you might have one. What there definatly is out there, is someone that will steal the idea given half chance.
I'd forget "not doing it for money" though. If you don't profit from it then someone else will! You can always donate the procedes to good causes later.
http://jpsc.org.uk/forum/
balidey
posted on 5/12/12 at 01:23 PM Reply With Quote
OK, my comments may have sounded a bit negative, it wasn't meant to be.
What I wanted to do was highlight that there are hundreds of people all over the world that have been working on this 'area'. OK you may have come up with a novel approach to it, but you could spend years and thousands of pounds to then suddenly find out Mr Smith patented the idea in 1976. Not saying that will be the case.
We are not strangers to litigation as we are on the locostbuilders site.
So I truly hope you do have an idea that can combat this problem. And if you do, good luck.
But I do have a great 'I told you so' dance I keep for special occasions at work.
Matt_C
posted on 5/12/12 at 01:25 PM Reply With Quote
I am working as a design engineer doing explosive protection equipment for the last few years, there are loads of absolutely crack pot idea produced in the sector (so of which have made money and been a commercial success).
You can only give it a go and see if anyone will buy into the principle. British MOD mainly like throwing money down a hole to anyone with a Dr in their title for no results at all, so maybe the more crackpot the better!
New MOD mine clearance vehicles they are testing have 4 inch thick armour steel on the under side and are still jumping 3 feet, as all terrorists do is increase the explosive quantity in the mine to counter any extra armour. Anti human mines are not designed to kill, that is the last thing the enemy want, it is all about creating casualties the opposition have to look after in the field. It is not a pleasant game.
Google Aigis Blast protection if you want to see a few of the things we do and what is already on the market. We also do explosive testing to get products certified into the market if that is any help when things are up and running.
Good luck
Matt
vanepico
posted on 5/12/12 at 01:40 PM Reply With Quote
If you write your idea on a letter, seal it, post it to yourself, receive it and leave it unopened you can use the post stamp date as copyright proof of your idea because the post date is legally reliable, i think i saw this on qi or something. As long as the envelope doesn't look tampered with.
__________________________
Will CAD for food/money/beer...
tegwin
posted on 5/12/12 at 01:47 PM Reply With Quote
Urban myth! Doubt it would stand up to much
Macbeast
posted on 5/12/12 at 02:02 PM Reply With Quote
Don't give details on here or anywhere else. By the time you get it into operation, the IUD merchants will have countered it.
posted on 5/12/12 at 02:24 PM Reply With Quote
Cleverest protection idea I ever heard of was using what is basically tarmac with cork mixed in as ad hoc armour for merchant ships, apparently weight for weight it is 90% as good as WW2 era rolled armour plate.
TimC
posted on 5/12/12 at 05:45 PM Reply With Quote
One of my best mates is in Bomb Disposal; just back from Afghan. Drop me some details and I'll put you in touch. He may know the right channels and will give you a view.
morcus
posted on 5/12/12 at 06:19 PM Reply With Quote
As others have said, keep it secret and try and find a way to date your idea just incase.
If you know anyone in the industry that you can trust it might be worth discussing it with them first to see if they think it will work or if it's been done before.
Contacting the Army directly will probably be a massive waste of time, you need to contact a technical department of the MoD if you want to go through that sort of result and see if you can be put in touch with an engineering team. Your best bet if you want to try and bypass the beraucratic elements is to try and write to someone at the place where they test tanks and artillery, I can't think what it's called at the moment, but it's were most of the Army testing is done.
If your idea is a product then you could try contacting all the militry contractors, or you could go to procurement (search DE&S on the MoD).
bi22le
posted on 5/12/12 at 06:24 PM Reply With Quote
Thanks for all of your help and advice people.
I have enough leads and details to get going on with.
Special thanks to the people that have sent U2U offering your help and particular advice \ leads for contact.
If its floored then Ill post my idea up on here. If it seems to float then you may hear about it on the news. If I run out of time and cant take it any further Ill post it on ebay!!
coyoteboy
posted on 5/12/12 at 07:49 PM Reply With Quote
FWIW the military have an open call for technology ideas like this, the centre for defence enterprise should help you nail this, they provide grants and work with you at pretty much any stage...
http://www.science.mod.uk/engagement/cde/working_with_cde.aspx
Going to their procurement or contractors will get you nada, from experience.
[Edited on 5/12/12 by coyoteboy]
<<  1    2  >>
