Author: Subject: C20xe flywheel /gearbox locator bearing
mcg
posted on 15/12/12 at 07:32 PM Reply With Quote
Hi. I am just in the process of changing my 8v vaux unit to a red top unitunit and have noticed that behind the flywheel on the redtop there is no bearing which i assume would be a locator for the end of the gearbox input shaft. (type 9) This means it was never there when working with the f18 gearbox on the corsa i got it from. Is this normal, or am i missing something? The old 8v unit has that bearing which i suppose i could transplant accross, but the engine is already in the car so i only want to do it if necesary.
Anyone have the same experience? What should I do? Thanks in advance.
Matt
striker-4age
posted on 15/12/12 at 08:16 PM Reply With Quote
Hi m8,
You need a manta or Carlton spigot bearing and away you go
Striker-4age
laptoprob
posted on 15/12/12 at 08:37 PM Reply With Quote
Matt
You will need to put one in unfortunatly otherwise the drive shaft will float inside the clutch plate and make a mess.
TYPE 9 GEARBOX SPIGOT BEARING for Ford Sierra Capri Escort Kitcar Pinto Zetec
mcg
posted on 15/12/12 at 09:03 PM Reply With Quote
Thanks alot. Makes sense.
Will probably get this one: Crankshaft Spigot / Pilot Bearing Carlton Frontera Omega Senator 90105743 Saab
Thanks again.
Matt
