Author: Subject: OT - tool to remove cap
posted on 20/12/12 at 10:54 AM Reply With Quote
How would you go about making a tool to remove this cap without damaging it?
overall diameter is 28 mm, recess is 14 mm.
Cover recess with cling film and then pack with epoxy resin/chopped glass fiber mat?
now if only I had a CNC or 3D printer....
liam.mccaffrey
posted on 20/12/12 at 11:35 AM Reply With Quote
I reckon you could vabricate somthing from 5 bits of bar welded on to a central pin.
Build Blog
Build Photo Album
Slater
posted on 20/12/12 at 11:41 AM Reply With Quote
screwdriver with some duct tape wrapped round the end to avoid metal bits contacting each other.........Locost style......
MikeR
figure out the size of the holes, cut down some bolts. Weld bolts onto bar. twist bar.
Technically you'd only need two bolts.
maccmike
posted on 20/12/12 at 11:42 AM Reply With Quote
round bar equal diameter to of the centre of cap.
5 small round bar equal to the 5 outer areas.
bit of welding and grinding.
jobs a good'n
tegwin
posted on 20/12/12 at 11:43 AM Reply With Quote
I have used large hex keys before with a piece of duct tape for padding on similar caps.
www.verticalhorizonsmedia.tv
HowardB
posted on 20/12/12 at 11:46 AM Reply With Quote
I have used the two screwdriver technique,... one in one slot as a pivot, the other in across the cap as a lever. It would be possible to replicate as a bar with just two pins, or three if you were worried. Not all 5 are required.
hth
Howard
posted on 20/12/12 at 11:51 AM Reply With Quote
thanks - good job i asked - 5 aluminium pins held in some fashion would be the easiest
Jimfin
posted on 20/12/12 at 12:44 PM Reply With Quote
Tool for changing wheels on the angle grinder perhaps, difficult to gauge the dimensions from the photo, but could also be made to size with a bar an couple of bolts..
matt_gsxr
posted on 20/12/12 at 01:41 PM Reply With Quote
What about making a tool out of that plastic that you can melt in boiling water?
trextr7monkey
posted on 20/12/12 at 02:16 PM Reply With Quote
known a s polymorph
I think Iwould just drill hole centres througha bit of flat bar and drop some bolts through - either put a nut on back or a spot of weld on top, how tight are they?
Have a cnc machine that works with wood and pladstic (but not metal on a big scale0
mIKE
theprisioner
posted on 20/12/12 at 03:04 PM Reply With Quote
CNC
Digitise the shape using TuboCAD or AutoCAD then cut it out of the solid, simples!
posted on 20/12/12 at 04:00 PM Reply With Quote
Looks a reasonably expensive part - is it for cycle brakes?
How much is the proper tool, might be cheaper in the long run to preserve the part. Don't foget you've got to do it back up again too.
posted on 20/12/12 at 06:24 PM Reply With Quote
Work out the PCD of the 5 pins, mark out the end of a larger diameter alloy bar, drill five suitably sized holes for the pegs and drive the pegs in. Drill hole through the side of large alloy bar and insert a drive bar.
If they aren't hugely tight you may be able to whittle down a bit of hardwood and get the job done.
fazerruss
posted on 20/12/12 at 07:53 PM Reply With Quote
Easy, all you need is a milling machine , a lathe and a rotary table!
"if assholes could fly this place would be an airport"
tomgregory2000
posted on 20/12/12 at 08:34 PM Reply With Quote
That looks like a cap of a mountain bike brake calliper
Just like the hope one
Just buy the tool
posted on 28/12/12 at 05:31 PM Reply With Quote
Just buy the tool
easier said than done, searching the web has thrown up nothing hence why I asked.
BTW it is Formula R1 brake calliper.
