Author: Subject: What amperage wire?
philhoward
posted on 21/12/12 at 09:04 AM Reply With Quote
What amperage wire?
What amperage wire do I need for wiring in a windscreen wiper motor?
HowardB
posted on 21/12/12 at 09:21 AM Reply With Quote
not sure on the current draw of the motor, but as most wipers have a fuse in line, the wire must be capable of handling at least the fuse current. If you have a 15Amp fuse then in my mind this needs to be the weak link not the cable.
hope that helps
Howard
dhutch
posted on 21/12/12 at 04:00 PM Reply With Quote
Cross sectional area, in millimetes, is the measurement typically used to size wire.
Boltsy
posted on 22/12/12 at 09:19 PM Reply With Quote
1.5mm single core multi strand should cover it. As previously advised, fuse the circuit to cover the motor current draw. Typically 15A will do for a wiper motor.
Limitation starts where the visions end - Jimmy Johnson
