posted on 23/12/12 at 10:07 PM |
1300 cross flow
Which cams best for road use don't want to have to alter pistons.
chillis
posted on 23/12/12 at 10:38 PM |
there's quite a big choice - depends what you want from the car. A mild improvement can be gained from upgrading a non-GT to GT spec.
Never under estimate the ingenuity of an idiot!
AndyGT
posted on 23/12/12 at 11:42 PM |
BCF 2 or absolute max BCF 3. It is the old spec but that is the limit before cutting pistons...
nothing is impossible
everything is possible
wonderfulweasel
posted on 23/12/12 at 11:55 PM |
I used to have a Piper 285 in my 1300. I didn't modify the pistons. I timed it up with a vernier pulley.
It had a big valve head, single 45 Weber, megajolt ignition and 4-2-1 manifold.
It produced 93bhp on two different rolling roads.
posted on 24/12/12 at 09:58 AM |
Will a1600 gt cam fit in the 1300 engine
black fingernail
posted on 24/12/12 at 10:06 AM |
Unless you are restricted by racing rules, why bother, just upgrade to a zetec, it will be cheaper, nicer to drive and more economical.
wonderfulweasel
posted on 24/12/12 at 10:10 AM |
Yes, a 1600gt cam will work in the 1300
Paul Turner
posted on 24/12/12 at 03:11 PM |
Surprised at that. Never used one personally but several mates did in the days when the x-flow was king and all needed piston mods just like I and
others needed with the Kent 234 and 244 alternatives.
[Edited on 24/12/12 by Paul Turner]
wonderfulweasel
posted on 24/12/12 at 10:04 PM |
Yep, checked the clearances during assembly. I think piper recommend that.
Used it happily for a couple of years, including sprinting. Only took it out to swap for a 1600.
