<<  1    2  >>
Author: Subject: Pre IVA Pictures For Comment
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 4/1/13 at 03:01 PM Reply With Quote
Hi All, I'm hoping I'm just about ready to apply for my IVA. I'm just waiting for the pictures of the build to come through the post then I'll get the forms sent off.
In the mean time, here are the latest pictures of my kit for you all to comment on anything I've missed before the big day.
I know about the following :
1. No side repeaters - gonna put them in the skuttle
2. Steering Wheel
3. Top seat belt need to have u surrounding
4. Mesh need to be put behind the front grill to prevent sharp edge failure.
5. Brake fluid reservoir warning sender need wiring up (will do this when doing the side repeaters)
6. The roll bar needs to be powder coated (but I can do this post IVA)
What else have I missed?
Linky
slingshot2000
posted on 4/1/13 at 03:06 PM Reply With Quote
How come it has a registration number on it ?
wicket
posted on 4/1/13 at 03:10 PM Reply With Quote
How come it has reg plates before it's been IVA'd?
daniel mason
posted on 4/1/13 at 03:15 PM Reply With Quote
are the nuts on the track rod end covered?
adithorp
posted on 4/1/13 at 03:24 PM Reply With Quote
Looks good.
Only things that come to mind are...
Are tthe seat belt mountings higher than the holes in the seat? If the belt goes upward to the ole then the seat becomes structural and it'll fail. Spacers and longer bolts will do if needed.
Do thefront indicators meet the max distance from the widest part of the car (usually the rear wheel arches) measurement. Do they mett the angles of visbility test and not be obscured by the cycle wings?
Will side repeaters on the scuttle meet the angles of visability test without being obscured by the rear arches? Lot's have had to fit to the front or rear arches to pass.
Do you have a brake fluid sticker/label?
Is it balance bar set up on the brakes and if so, do you have the warning sticker/label?
Have you checked the radius of the groves in the gear lever and the bike clocks? Clocks might need a shroud or padding. d O rings on the lever would do for that.
Whats the number plate? Shouldn't have one yet.
http://jpsc.org.uk/forum/
loggyboy
posted on 4/1/13 at 04:00 PM Reply With Quote
Scuttle mounting may fail the 5degree rearward visablity splay, the rear arches can get in the way.
Mistral Motorsport
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 4/1/13 at 04:05 PM Reply With Quote
The reg is from the donor car so I could see what it all looks like when finished.
I lucked out on the reg number of the donor car having MK in it too.
[Edited on 4/1/13 by Barkalarr]
DavidW
posted on 4/1/13 at 04:20 PM Reply With Quote
I put them on the front arches to pass IVA. I still have those arches which 'fell off' shortly after IVA.
I also have the top seatbelt mounting cover which fell off a few weeks ago.
Not sure if it's any use but I travel to Chelmsford a lot if you want to borrow them?
It looks like a good build. Where are you going for IVA?
clanger
posted on 4/1/13 at 04:23 PM Reply With Quote
dunno about IVA, but looks a good qaulity build
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 4/1/13 at 04:36 PM Reply With Quote
Yes, they're covered. There's a new pictures showing both sides Here and Here
Pdlewis
I couldn't see enough to tell but it looks like the level switch on the brake reseviors are not attached to anything
Build Photo Album
Updated 05/02/2009
loggyboy
posted on 4/1/13 at 04:37 PM Reply With Quote
I have heard of them failing there too, due to the fact that when you turn the wheels you cant see them from certain angles.
Safest place is rear arches, but i have seen cars pass with them both on scuttle and on front arches! IVA=Lottery
Mistral Motorsport
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Sent u2u
loggyboy
posted on 4/1/13 at 04:38 PM Reply With Quote
Mistral Motorsport
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Not at the moment - this will be done when I do the side repeaters (get all the wiring jobs done at the same time).
Pdlewis
doh should read properly!!
Build Photo Album
Updated 05/02/2009
loggyboy
posted on 4/1/13 at 04:41 PM Reply With Quote
How well can you see out of the rear mirrors when seated? as they are top mounted they seem quite close inboard, meaning your shoulder may obsure some of the view.
Mistral Motorsport
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 4/1/13 at 04:47 PM Reply With Quote
Originally posted by adithorp
Looks good.
Are the seat belt mountings higher than the holes in the seat? - Good point, well made - will check this.
Do the front indicators meet the max distance from the widest part of the car - yes, I've checked this.
Do you have a brake fluid sticker/label? - thanks, need to get this.
Is it balance bar set up on the brakes and if so, do you have the warning sticker/label? - it's been locked off - do I need a sticker?
All the other things you mention I'm going to have to chance my arm - if it fails then I'll just fix it for the retest. I'll be taking some tie wraps, rubber and u channel with me in case there's anything silly I've missed.
macc man
posted on 4/1/13 at 05:14 PM Reply With Quote
The handbake could do with a cover over the mechanism. Prevents fingers being trapped. Very nice build.
wicket
posted on 4/1/13 at 05:53 PM Reply With Quote
If you get age related at registration you won't get to keep the donor reg, you will just get the same year.
renetom
posted on 4/1/13 at 06:03 PM Reply With Quote
IVA
Hi
Our Indy R1 failed on several points the first time
I see several points on yours which need seeing to
Holes in seats need the same edge trim as around
Handbrake needs gaiter for sharp edges
Do the tunnel edges meet the radius req ? does not look like it.
Rear view mirror
Front indicators ? visibility ?
sharp edges to side panels, look sharp to me.
Radiused edge to dash ?
Needs momentary switch for brake test, fluid level, handbrake all wired in
Start switch ? in front of gear lever , probably need a cover .
Not sure on clock radiuses ?
Side indicators to rear arches as we were told by IVA inspector
Having failed ours on the scuttle.
Emissions were our worst problem with a carbed R1.
Do you still have the AIS a there is a simple solution to overcome this.
Good luck
René
indicators
indicators
Being led you will need resistors
[Edited on 4/1/13 by renetom]
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 4/1/13 at 06:22 PM Reply With Quote
Originally posted by renetom
Hi
Rear view mirror
Good luck
René
indicators
indicators
Hi Rene some good points there thanks.
That's not the start switch - that's the reverse switch. You start it like a normal car on the key.
I must add a sticker to my new list of to do's that says "reverse"
I didn't want to make it too complex to start because my father wants to drive it too - say no more lol
Mine is a fuel injected R1 but like you I suspect the emissions is going to be a problem. What do you mean by AIS ?
If it fails I will address the problem then. I can't get it to an MOT station to check the emissions and I don't have a tester handy in my garage. Other than hire a trailer and mess about I don't reall know what choice I have other than see if it fails on emissions.
Ben_Copeland
posted on 4/1/13 at 10:04 PM Reply With Quote
Bin the number plates, you wont get that number anyway.
Will the bike clocks pass sticking out of the dash? Radius's etc
Ben
Locost Map on Google Maps
Enter Your Details Here
renetom
posted on 5/1/13 at 10:00 AM Reply With Quote
iva
Hi
The AIS is the air induction system, your being a later model is different to ours
but does the same job,
AIR INDUCTION SYSTEM
The air induction system burns unburned exhaust
gases by injecting fresh air (secondary
air) into the exhaust port, reducing the emission
of hydrocarbons.
We failed on the lambda reading being far too high , so I removed the pipe from the
airbox to the AIS valve & fitted a 15mm push fit stop tap on the end.
This allowed me to turn down or off the air going into the exhaust whilst he was doing the test.
We had to turn it off completely & it passed with flying colours.
Costs next to nothing & everything to gain if it works.
Make sure there are no air leaks on any part of the exhaust system
& get the cat nice & hot before the test .
Re:Switch If his ball (representing a head) fits behind the gear lever he will fail it on that or radiuses
Make sure the pedals have rubber boots or non slip
In the footwells if there are any protrusions bolts rivets etc, cover them!.
I know a lot of the test is B----cks but if he sees that you have made a real effort , that goes a long way.
Good luck
rené
austin man
posted on 5/1/13 at 10:41 AM Reply With Quote
Only way you will get the number is if you have it on retention and tranfer it to the car after registration. If its not on retention you will be given a number
<<  1    2  >>
