Author: Subject: What nails for stud walling?
ChrisW
posted on 7/1/13 at 01:16 PM Reply With Quote
Appealing to the LB collective knowledge, I hope we have some builders on here?
I've got a stud walling project to do. 26 linear meters. It was recommended that I hire a Paslode 'first fix' nail gun which I have done (well, reserved it anyway) but the next question was 'which nails do I need'.
I'm using 3x2 to build the frame and am going to clad with 6mm plywood then fireboard. The plywood is to try to give the walls the impression of being more solid.
So the question is what nails should I ask for?
Chris
My gaff my rules
rgrs
posted on 7/1/13 at 01:56 PM Reply With Quote
3.1 x 90 normally but do check which gun you have hired, i.e. im350 or im90.
Don't be tempted to buy the really cheap packs on Ebay you will only regret it.
Roger
ChrisW
posted on 7/1/13 at 01:59 PM Reply With Quote
Thanks Roger.
It's an IM350 gun.
Is that the same as '31/90'? Do I want 'galv' or 'ring galv'?
Point taken about the eBay packs. I'm using their listings to get a guide for the sizes but I'll buy the nails from the place I get the gun from.
Chris
My gaff my rules
mookaloid
posted on 7/1/13 at 02:59 PM Reply With Quote
Ring Galv. - the rings grip the timber better and they don't creak if the floor moves.
chillis
posted on 7/1/13 at 03:05 PM Reply With Quote
26 linear meters sounds like a new workshop
When mine was done the building company screwed it all together as they reconned it was stronger than nailing. Certainly is pretty rigid.
Never under estimate the ingenuity of an idiot!
ChrisW
posted on 7/1/13 at 04:43 PM Reply With Quote
Thanks for all the input guys.
I did the sums again and realised it's 34m, not 26. Good job I double checked!
Chris
My gaff my rules
renetom
posted on 7/1/13 at 05:41 PM Reply With Quote
Partition
Hi
we have been doing partitioning for nearly
30 years we always screw the ply on with a few screws
Just enough to hold them in position then the fireline boards
with 42mm drywalls square or tapered edge depending on
finish required.
Good luck
http://rhthomas.co.uk/
Give me a ring if you want , no on the website Mobile is best.
René
[Edited on 7/1/13 by renetom]
Neil2004
Contributor
Posts 44
Registered 21/1/04
Member Is Offline
Photo Archive Go!
Building: Purchased Sylva Star, updating with Zetec engine,
posted on 7/1/13 at 06:49 PM Reply With Quote
It's best to screw fix the plasterboard. There are special screws for this and you will avoid 'nail popping' which is where nails work themselves out of the wood and cause the plaster that's covering the screws to 'pop off'. Also if you are looking for the ply to provide a fixing for shelves etc you probably need to use a thicker ply or reduce the stud centres. British Gypsum has an excellent website with instructions on how to install a timber stud wall. The Sitebook gives specific information and a section on stud wall can be found at: www.british-gypsum.com/literature/site book
As a final thought Fire line board is pretty strong and robust. If you you require from the ply is robustness then I think you could omit this. If you're really concerned about strength then you could look to use Fermacell, which is a gypsum fibreboard is very strong and takes a screw fixing.
