Author: Subject: Asbestos Garage Roof Removal
JonBowden
posted on 17/1/13 at 01:29 PM Reply With Quote
Can anyone give me an idea what it costs to have asbestos/concrete roofing removed from an old out house?
I am looking at about 100 sqm of roofing material to be removed.
I am not looking to have the roof replaced (I can do that myself), just want rid of the asbestos.
Jon
Mark2
posted on 17/1/13 at 01:47 PM Reply With Quote
Have done this myself recently, the official word is to get a company in to remove it but this can be done yourself, there are local council tips that will take it, it has to be double baged a taped, I was able to take mine in full sheets, it only courses a problem if you have to break them up which I don't advise as then you have a possibility of the fibres getting airboure. BUT AGININ THE BEST WAY IS GET A PROFFESIONAL REMOVAL FIRM TO DEAL WITH IT...
Cheers Mark
https://www.facebook.com/WestfieldSportsCarClubWirralNorthWales?ref=hl
posted on 17/1/13 at 01:53 PM Reply With Quote
Get a load of old pallets, build a big bonfire and burn it all.
locoboy
posted on 17/1/13 at 01:56 PM Reply With Quote
I took mine to the local tip, bagged and in whole sheets.
Put them in a designated shipping container labelled 'asbestos', job done.
Locoboy
v8kid
posted on 17/1/13 at 02:00 PM Reply With Quote
As Mark2 says.
Whilst the asbestos is bound into the cement it is harmless its only when the sheet is drilled, cut, broken or disintegrating that it is a concern. I found the local authority helpful - they don't want fly tipping after all so contact them to see what their bagging requirements are. As well as double bagging I had to clearly mark the bags as asbestos cement waste. A key point is if you are doing it as a private individual different regulations apply from an asbestos removal company who have reams of paperwork and certificates to complete.
I read the HSE guidelines before I did mine and acted on them - again they were very helpful.
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
owelly
posted on 17/1/13 at 02:41 PM Reply With Quote
And I'll just add:
If you do break a sheet or its damaged, spray it with a wate and PVA mix to stop any dust.
http://www.ppcmag.co.uk
Agriv8
posted on 17/1/13 at 03:26 PM Reply With Quote
Saved me posting an almost identical post.
Most usefull
Thanks Agriv8
mcerd1
posted on 17/1/13 at 04:01 PM Reply With Quote
second that - the HSE website is very useful
these will get you started:
http://www.hse.gov.uk/pubns/guidance/a14.pdf
http://www.hse.gov.uk/pubns/guidance/a11.pdf
loads more reading on the website
we've removed alot more than 100mm² of the stuff ourselfs
[Edited on 17/1/2013 by mcerd1]
dave r
posted on 17/1/13 at 05:33 PM Reply With Quote
Most usefull
Thanks Agriv8
and a 3rd one.....
mine you all that looks like asbestos roofing , isnt
we paid for someone to remove some at work, and after they had finished they told us it wasnt.......
still charged us though
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
parkiboy
posted on 17/1/13 at 06:35 PM Reply With Quote
We deal with it a lot at work, I can't believe nobody has mentioned, make sure you wear a mask to protect yourself, paper masks suffice but make sure it's the correct ones, not all will keep asbestos out. Also ideally you want to be wearing a paper suit incase of any mishaps to stop you contaminating your clothes which in effect can contaminate your house.
Dopdog
posted on 17/1/13 at 07:11 PM Reply With Quote
lets not forget you get 3 versions and the smallest fibre can cause an issue, you must be very careful with it.
zilspeed
posted on 17/1/13 at 07:17 PM Reply With Quote
And let's also not forget that there is licenced and unlicenced work dependent on the material.
I'm not going to comment too far here, but it's far from being as simple as double bag and put into the asbestos skip at the tip.
It's up to you if you want the HSE getting personal.
Up to you.
parkiboy
posted on 17/1/13 at 07:36 PM Reply With Quote
From memory the asbestos cement used in garages is normally white asbestos and is unlicensed but I would double check.
Dangle_kt
posted on 17/1/13 at 07:42 PM Reply With Quote
A friends dad died of asbestosis, its not a nice way to go.
zilspeed
The only way you'll ever know of course is by a lab test of a sample.
jabs
posted on 17/1/13 at 08:19 PM Reply With Quote
Try the council, I once had a garage made of the cement bound stuff and I just dismantled the garage and the council came and collected FOC - was a few years ago mind so as they are all cash strapped these days they may want to charge
[Edited on 17/1/13 by jabs]
dave
posted on 17/1/13 at 08:37 PM Reply With Quote
I done some training on Asbestos a few months ago and the link shows how much we did not know about it.
http://www.mesothel.com/asbestos-cancer/exposure/asbestos_roulette.htm
Bare
posted on 18/1/13 at 03:33 AM Reply With Quote
Effing Safety Nazis and snivel servants. Yes Asbestos Can be dangerous ..IF.. inhaled.
Try not to inhale it!??
What the morons in the Cheap Suits have not yet cottoned onto .. yet!.. is that Fiberglass.. as found in House insulation AND cigarette filters is EVERY bit as dangerous as Asbestos. Wait a few more years until the Public twits realise this
Just a thought to brighten your Day :-)
[Edited on 18/1/13 by Bare]
mcerd1
posted on 18/1/13 at 08:09 AM Reply With Quote
^^ all on the HSE website (as mentioned / linked to above) - they give detailed advice on the levels of protection
they also give guidance on working out what your dealing with and when you need a licened contrator (aswell as providing a list of contractors)
deezee
posted on 18/1/13 at 12:43 PM Reply With Quote
Is this out building yours, or is it a job you're business is doing? I only ask because the HSE has zero involvement with private work on domestic property. I could climb on the roof of my house in my boxers to change a tile, in the snow, and its nothing to do with the HSE. If you want to collect asbestos in your bedroom the HSE can't stop you. The Environmental agency might have something to say, but not the HSE.
Bluemoon
posted on 18/1/13 at 01:14 PM Reply With Quote
I doubt it not saying you are wrong but the problem asbesdos fibers have barbs on it (unlike fiberglass)... Thus once in your lung it will not come back out...
[Edited on 18/1/13 by Bluemoon]
Dopdog
posted on 18/1/13 at 01:24 PM Reply With Quote
well said bluemoon was waiting for someone to point this out.
JonBowden
posted on 19/1/13 at 09:21 PM Reply With Quote
Thanks for the feedback. The outbuilding I was asking about is part of a house that I am considering buying.
I did phone a specialist company near Glasgow. They gave an estimate of £2250 to remove and dispose of the asbestos panels
Jon
SteveWalker
posted on 19/1/13 at 09:49 PM Reply With Quote
If it were me, I'd use the cost and inconvenience of having it removed to beat down the house price and then remove it all myself!
Keep it wet - even better, remove it on a rainy day. Don't saw it. Try to avoid breaking it. Double bag it. Take it to the local "tip" - check your local authorities policy first.
From what I've been told, a lot of "asbestos" roofing actually contains no asbestos.
SteveW
